Aimeos Logo in Dashboard
webmaster
Post by webmaster » 10 Feb 2024, 11:25
Hello i am new here and i have discover this ecommerce this week and i want to start to work with that .
First thing i want to change the logo in dashboard, but i can change it i only ended up changing logo in website.
My php version is : 7.4.3
Aimeos is the myshop version that i have installed using composer : php composer create-project aimeos/aimeos myshop
Gagik
Re: Dashboard
Post by Gagik » 10 Feb 2024, 12:23
Hi.
Do you mean 'Aimeos' logo in top left in the admin panel ?
webmaster
Re: Dashboard
Post by webmaster » 10 Feb 2024, 12:28
yes that logo ,
Gagik
Re: Aimeos Logo in Dashboard
Post by Gagik » 10 Feb 2024, 14:01
Please overwrite this file into your extension.
https://github.com/aimeos/ai-admin-jqad ... L135-#L137
webmaster
Post by webmaster » 13 Feb 2024, 11:53
can you please tell me the right path to it, because in :vendor\aimeos\ai-admin-jqadm\admin\jqadm\templates
i can't find page.php
Gagik
Post by Gagik » 13 Feb 2024, 14:39
The right way is:
vendor\aimeos\ai-admin-jqadm\templates\admin\jqadm\page.php.
But you have to overwrite this file into your extension directory like that:
packages/EXTENSION_NAME/templates/admin/jqadm
Post by aimeos » 14 Feb 2024, 08:23
webmaster wrote: 10 Feb 2024, 11:25 My php version is : 7.4.3
You say, you have PHP 7.4 but only old versions of Aimeos are available for that unsupported PHP version.
Please upgrade to 8.1/8.2/8.3 first and install the current Aimeos version afterwards.
webmaster
Post by webmaster » 14 Feb 2024, 12:43
ok thank you i was having trouble finding some folders
webmaster
Post by webmaster » 14 Feb 2024, 14:24
i have installed php 8.2.12 now i have some sql errors like : Syntax error or access violation: 1176 Key 'unq_msindca_p_s_cid_lt_po' doesn't exist in table 'mindca,
before that i have error that says : Base table or view not found: 1146 Table 'aimeos.mshop_index_catalog' doesn't exist: SELECT mpro."id" , MIN(mindca."pos") AS "s0", MIN(mpro."id") AS "s1" FROM "mshop_product" mpro LEFT JOIN "mshop_index_catalog" AS mindca USE INDEX ("idx_msindca_s_ca_lt_po", "unq_msindca_p_s_cid_lt_po") ON mindca."prodid" = mpro."id" WHERE
Post by aimeos » 15 Feb 2024, 08:36
Seems like there has been a dependency problem introduced in the setup tasks for 2023.10.x LTS recently. Can you please install Aimeos from scratch?
