I can not find outputs of cronjobs (product/export, product/export/sitemap)
beenzu
Post by beenzu » 22 Feb 2024, 06:42
I have run the following cronjobs:
php artisan aimeos:job "product/export product/export/sitemap" "default_2bd1f".
Nothing shows after that. I also tried them individually. Where do I find the outcome or result?
Gagik
Re: I can not find outputs of cronjobs (product/export, product/export/sitemap)
Post by Gagik » 22 Feb 2024, 07:53
Hi
It's a default behavior of this use-case just like for example "php artisan aimeos:clear". You have to add change to your code.
beenzu
Post by beenzu » 22 Feb 2024, 09:01
Thanks for the hint.I am new to Aimeos. Where do I change the code and to what?
Gagik
Post by Gagik » 22 Feb 2024, 13:44
You can call 'info' method like this: '$this->info(...)' for them some results.
Post by aimeos » 23 Feb 2024, 10:56
If you only want to see the files that are generated (when using Laravel):
The product export is stored in ./storage/export/ and sitemap files are stored in the ./public/ directory of your application
