Configure Aimeos Frontend
Tboi
Post by Tboi » 25 Feb 2024, 08:24
Hi. I've installed Aimeos distribution in typo3 and I would like to customize and change the theme, how do I do it?
Aimeos v 23.10
PHP v 8.2.12
Linux System
Re: Configure Aimeos Frontend
Post by aimeos » 25 Feb 2024, 11:38
If you only want to adapt the theme partly, then you can add a custom CSS file to every page.
In case the theme should be totally different, you can copy the existing theme to a new directory (e.g. in /fileadmin) and adapt the resource configuration to the new theme using TypoScript:
https://github.com/aimeos/aimeos-typo3/ ... hp#L58-L63
The "basedir" and "baseurl" settings need to be overwriten:
plugin.tx_aimeos.settings.resource.fs-theme.basedir = /path/to/absolute/fileadmin/theme
plugin.tx_aimeos.settings.resource.fs-theme.baseurl = /fileadmin/theme
Tboi
Post by Tboi » 25 Feb 2024, 12:25
Where are the theme files that are being used by default located in the myshop folder, I can't seem to get the them
Tboi
Post by Tboi » 25 Feb 2024, 20:55
I have a fully functioning frontend with all its JS, html and css. All its pages are working and I now want to link that Web frontend to aimeos backend for management of products, currencies, page info etc. How can I do that
Post by aimeos » 27 Feb 2024, 10:23
Can you explain that in more detail? We are unsure what you want to do
Tboi wrote: 25 Feb 2024, 12:25 Where are the theme files that are being used by default located in the myshop folder, I can't seem to get the them
The files are located here:
https://github.com/aimeos/aimeos-typo3/ ... es/default
Tboi
Post by Tboi » 27 Feb 2024, 13:08
aimeos wrote: 27 Feb 2024, 10:23 Can you explain that in more detail? We are unsure what you want to do
I have a fully developed web view, the html and css is ready. I want to just take it as it is and integrate it with aimeos so that I can manage it's content through aimeos admin backend.
Post by aimeos » 29 Feb 2024, 08:32
If you want to display the output of Aimeos HTML client components, please have a look here:
- https://github.com/aimeos/aimeos-larave ... p#L75-L107
- https://github.com/aimeos/aimeos-larave ... .blade.php
