Adapting Aimeos theme
sbaca
Post by sbaca » 03 Mar 2024, 14:58
Hello everyone,
After having installed the Aimeos standalone application with Laravel, I would like to adapt the style of some parts of the theme (e.g., navbar, background color, etc.).
I have created the public/mytheme folder at the root of the project with the following files within it: aimeos.css and aimeos.js, then I have copied the vendor/aimeos/aimeos-laravel/views folder to the resources folder, at the root of the project.
I have also added the links to my custom CSS and JS files to the base.blade.php file that I have copied from the vendor/aimeos/aimeos-laravel/views folder, but none of my edits are working. However, when I edit the public/vendor/shop/themes/default/aimeos.css file, it works perfectly.
Can you help me? I am available to provide you with more information.
Thank you
Re: Adapting Aimeos theme
Post by aimeos » 04 Mar 2024, 08:11
Did you copy the base.blade.php template to ./resources/views/shop/base.blade.php?
See: https://aimeos.org/docs/latest/laravel/ ... -templates
Check if the generated page contains your links to your CSS/JS file.
sbaca
Post by sbaca » 04 Mar 2024, 17:13
Thank you for your help!
I copied the base.blade.php file from vendor/aimeos/aimeos-laravel/views to resources/views/vendor/aimeos/shop/views
Post by aimeos » 04 Mar 2024, 17:24
Your destination path is wrong, use the path mentioned above.
sbaca
Post by sbaca » 04 Mar 2024, 18:13
aimeos wrote: 04 Mar 2024, 17:24 Your destination path is wrong, use the path mentioned above.
Thank you! It works perfectly!
