Best method for adding selection error message?
bpqr
Post by bpqr » 09 Mar 2024, 18:38
Laravel 10, Berlin Theme
We have begun to move products from Magento into Aimeos. One area we want to customize is the error message displayed when a product is attempted to add to cart without selecting one of the radio buttons for size/color. Presently it appears to just change the color of the selection text to --ai-danger.
Is there a generally accepted method for enhancing this? Ideally something to make it clear to customers that they need to select an option, instead of simply changing the color to --ai-alert CSS value. Before we started working on adapting this, I figured we'd see what was recommended.
All around impressed with the code and performance.
Re: Best method for adding selection error message?
Post by aimeos » 11 Mar 2024, 12:58
Add the error messages where they should appear in the template and hide them by default by adding "display:none" in the CSS file for those messages. If one of the message (or several) should be shown, add a CSS class (which contains "display:block") to the messages by Javascript. You can the JS code to add/remove the CSS class for the error messages here:
https://github.com/aimeos/ai-client-htm ... #L272-L612
