datasets
antoniosequeira66
datasets
Post by antoniosequeira66 » 27 Apr 2024, 10:15
Hello all,
is anyone working with these datasets: https://aimeos.org/docs/2024.x/config/a ... m/dataset/
I've set up a simple dataset in my shop.php config file, I see the dataset select box when i'm creating a new product but nothing else happens.
I can't find more documentation than this: https://aimeos.org/docs/2024.x/config/a ... m/dataset/
Can some one point me the way?
Thanks in advance
A.
Re: datasets
Post by aimeos » 28 Apr 2024, 15:59
What did you try in the config and what do you want to achieve?
antoniosequeira66
Re: datasets
Post by antoniosequeira66 » 28 Apr 2024, 22:52
first of all I try the examples from docs
https://aimeos.org/docs/2024.x/config/a ... t/#product
with T-Shirt and Books.
I see the dataset when adding a new product but nothing changes.
I'm developing a chocolate gift project where I have several custom type of products like a chocotelegram where I want to add a "keypad" made of chocolate letters, a box made of chocolate letters and others and so on.
I consider creating specific product types
Maybe not the correct approach....
Thanks for pointing me the correct way
A.
Re: datasets
Post by aimeos » 30 Apr 2024, 11:05
There had been a couple of issues with data sets and the documentation wasn't up to date.
Please get the latest commit using:
composer req aimeos/ai-admin-jqadm:2024.04.x-dev
