Adding a custom delivery status
promptnet
Post by promptnet » 24 May 2024, 14:00
we are missing the delivery status "ready for pickup".
How can we add that new delivery status which invokes a delivery email, too?
Re: Adding a custom delivery status
Post by aimeos » 25 May 2024, 21:34
If possible, re-use STAT_DISPATCHED if you don't use it yet. The meaning is more or less the same when it comes to pick-up. Otherwise, you would have to overwrite the job controller and the order list/item template in the admin backend and add a new status there (>=100 to avoid clashes with added status values in the future).
promptnet
Post by promptnet » 31 May 2024, 07:16
Thanks. I'll check back with the client.
