Add new query from Aimeos GraphQL
webmasterton
Post by webmasterton » 02 Jul 2024, 18:38
I created a new entity using the manager and I want to receive records from the new table in the order template of the administrative panel, similar to customer :
<Multiselect class="item-customer form-control"
	value-prop="customer.id"
	track-by="customer.id"
	label="customer.code"
	@open="function(select) {return select.refreshOptions()}"
	@input="useCustomer($event)"
	:value="item"
	:options="async function(query) {return await customer(query)}"
	:disabled="!can('change')"
	:resolve-on-load="false"
	:filter-results="false"
	:can-deselect="false"
	:allow-absent="true"
	:searchable="true"
	:can-clear="false"
	:required="true"
	:min-chars="1"
	:object="true"
	:delay="300"
	>&nbsp;</Multiselect>
but I can’t figure out how to implement and add new methods for querying in graphQL such as useCustomer and customer
when requesting with my entity I get an error :
message
"Cannot query field \"searchSellers\" on type \"query\". Did you mean \"searchOrders\", \"searchReviews\", \"searchRules\", \"searchSuppliers\", or \"searchCustomers\"?"
Re: Add new query from Aimeos GraphQL
Post by aimeos » 04 Jul 2024, 08:13
To create GraphQL queries and and mutations for your new data domain automatically, add the domain name in ./config/admin.php of your own extension:
return [
	'graphql' => [
		'domains' => [
			'mydomain' => 'mydomain'
See: https://github.com/aimeos/ai-admin-grap ... /admin.php
webmasterton
Post by webmasterton » 12 Jul 2024, 09:25
Thx its work
