How to Restore Guest Basket After User Login in Aimeos
unknow76616
Post by unknow76616 » 04 Jul 2024, 09:43
Hi everyone,
I am currently working on an Aimeos Laravel and I'm facing an issue with handling user baskets. Specifically, I want to restore the basket of a guest user after they log in to their account.
Here's the scenario:
* A guest user adds items to their basket.
* The user then decides to log in.
* After logging in, I want the items from their guest basket to be merged with their existing user basket (if they have one), or simply use the guest basket if they don’t have an existing basket.
i want something like this
$gust_basket_id = $session->get('aimeos/basket/list');
            if (Auth::attempt($credentials, true)) {
                $request->session()->put('aimeos/basket/list', $gust_basket_id);
but this not working ... :?
unknow76616
Re: How to Restore Guest Basket After User Login in Aimeos
Post by unknow76616 » 04 Jul 2024, 10:10
I commented this line
// $request->session()->invalidate();
Now the basket works as expected.
I hope this does not break anything else?
Post by aimeos » 08 Jul 2024, 08:58
Where did you remove that line? It may cause a security issue but not sure.
unknow76616
Post by unknow76616 » 08 Jul 2024, 09:22
Thanks , I confirmed that it doesn't have any negative impact.
AuthenticatedSessionController.php > create(Request $request)
public function create(Request $request): View{
            $request->session()->regenerateToken();
            return view('auth.shop-login', ['logo' => $logo]);
