How can I get the product variant url
thestranger
Post by thestranger » 17 Jul 2024, 10:02
Hello, I noticed this piece of js code in catalog-detail.js and I'd like to know how can I get the correct url so we can make promos on some variants so when people click on the link the product variant is preselected.
	 * Check for variants in URL
	 * Set the variant attributes and trigger select-dropdown´s to show the variant article
	onSelectVariant() {
		const product = $('article.product');
		if(product && product.data('varattributes')) {
			$.each(product.data('varattributes'), function (key, val) {
				$('#select-' + product.data('id') + '-' + key).val(val).trigger('change');
thestranger
Re: How can I get the product variant url
Post by thestranger » 17 Jul 2024, 12:07
got up to this link http://localhost:8081/default/shop/asdf/0/26501?d_articleid=26504 which produces the varattributes in javascript but there's no effect on the ui.
Post by aimeos » 17 Jul 2024, 12:20
This is what's relevant for the UI:
thestranger
Post by thestranger » 18 Jul 2024, 06:37
yea I did the console log and it works till there but i think the problem is that .trigger('change') does not work or something since it doesn't select the variant options in the ui (could it be because I'm using radio buttons and not dropdown select?)
Post by aimeos » 19 Jul 2024, 08:31
Most likely, the "change" trigger must be added when the document is loaded. Can you check and create a pull request with the necessary change afterwards?
