Extend order/manager/standard wit own throws ertror in jsonapi
heural
Post by heural » 26 Jul 2024, 14:32
Hi Aimeos-Team,
I extend (overwrite) MShop/Order/Manager/Standard with my own Customerordermanager,
purpose is to generate a custom invoice number (MShop/Order/Manager/Standard::createInvoiceNumber)
in config/mshop.php I have defined
return [
    'order' => [
        'manager' => [
            'name' => 'Customordermanager'
(see https://aimeos.org/docs/2022.x/config/m ... er/#name_2)
But now if I try to add a product to the basket, an exception is thrown in
aimeos/ai-client-jsonapi/src/Client/JsonApi/Basket/Product/Standard.php line 337 with message
"Klasse "\Aimeos\MShop\Order\Manager\Base\Product\Attribute\Customordermanager" nicht verfügbar"
What I doing wrong or is it a bug?
aimeos/aimeos-core 2022.10.16
aimeos/ai-client-jsonapi 2022.10.4
Thank you for your support!
Thanks a lot!
Re: Extend order/manager/standard wit own throws ertror in jsonapi
Post by aimeos » 28 Jul 2024, 09:29
Did you overwrite that method and pass another value as default name?
https://github.com/aimeos/aimeos-core/b ... #L966-L976
Does it work if you remove your configuration again?
Please note that 2022.10 is supported by the ELTS program of the Aimeos company only.
heural
Post by heural » 29 Jul 2024, 14:00
I dont overwrite this method but yes I overwrite in config/mshop.php order/manager/base/name and order/manager/base/product/name.
We use offically 2023.x but I´ve tested locally on my system with 2022.x
In 2023.10 this issue seems not exists, it works as expected!
Thanks a lot!
Post by aimeos » 30 Jul 2024, 08:45
Yes, in 2022 the manager name of the order product manager is used for the order product attribute manager too. This isn't the case in later versions any more.
