api add product
yesusagayaraj
api add product
Post by yesusagayaraj » 03 Aug 2024, 11:02
Hi Team
I have create product details through custom API but my details not added to the mshop_product_list table. Any changes needed
My code below
$manager = MShop::create( app( 'aimeos.context' )->get(), 'product' );
// Create new product item
$product = $manager->create()->setCode($request->code)->setLabel($request->name);
// Save the product
$manager->save( $product );
// Set product price
$priceManager = MShop::create(app('aimeos.context')->get(), 'price');
$price = $priceManager->create()
->setValue($request->price)
->setCurrencyId($request->currency_id)
->setType('default') // Set the type of the price
->setDomain('price'); // Set the domain for the price item
$price->getRefItems()->add(['product' => [$product->getId()]]);
$priceManager->save($price);
// Set product stock
$stockManager = MShop::create( app( 'aimeos.context' )->get(), 'stock' );
$stock = $stockManager->create()->setStockLevel($request->stock)->setProductId($product->getId());
$stockManager->save( $stock );
// Set product media
if($request->media_file) {
$mediaManager = MShop::create( app( 'aimeos.context' )->get(), 'media' );
$media = $mediaManager->create()->setFileName($request->media_file)->setMimeType('image/jpeg');
$media->getRefItems()->add( ['product' => [$product->getId()]] );
$mediaManager->save( $media );
return response()->json(['status' => 'Product created successfully']);
Re: api add product
Post by aimeos » 08 Aug 2024, 08:12
You have to connect the price/media/text items to the product item via a list item like described here:
https://aimeos.org/docs/latest/models/m ... ated-items
Currently, you try to connect the product item to the price/media/text item which doesn't work (it must be the other way round).
yesusagayaraj
Add product details using API
Post by yesusagayaraj » 09 Aug 2024, 06:49
Hi Team,
I want to using create product through mobile app. Please help how will create product details using like name, price , stock , media API
Re: api add product
Post by aimeos » 09 Aug 2024, 11:34
Example:
$context = app( 'aimeos.context' )->get();
$manager = MShop::create( $context, 'product' );
// Create price
$priceManager = MShop::create($context, 'price');
$price = $priceManager->create()->setValue($request->price)->setCurrencyId($request->currency_id);
// Add price to product
$product->addListItem( 'price', $manager->createListItem(), $price );
// Save the product
