STRIPE SETUP
bajwa
STRIPE SETUP
Post by bajwa » 03 Sep 2024, 18:49
How can i setup stripe payment system i've ran the command i found in the docs "composer req aimeos/ai-payments omnipay/stripe" now what should i do for the stripe payment system to appear in checkout and test if it's working or not
Re: STRIPE SETUP
Post by aimeos » 03 Sep 2024, 18:59
Go the the Setup > Services panel in the admin backend, add a new service, choose "Payment" as type and "Stripe" as provider. Add the necessary configuration in the config table:
- https://aimeos.org/docs/latest/manual/service-details/
- https://aimeos.org/docs/latest/manual/services/#stripe
bajwa
Re: STRIPE SETUP
Post by bajwa » 03 Sep 2024, 22:27
It says confirmed your order and everything and we are sending you an email but i dont receive any email i am giving real email in testing how to setup the email system
Re: STRIPE SETUP
Post by aimeos » 04 Sep 2024, 10:27
Did you set up the required cronjobs: https://aimeos.org/docs/latest/laravel/setup/#cronjobs
bajwa
Re: STRIPE SETUP
Post by bajwa » 05 Sep 2024, 03:58
NO PLEASE TELL ME HOW TO DO IT STEP BY STEP FOR EMAIL AFTER AN ORDER IS COMPLETED
bajwa
Re: STRIPE SETUP
Post by bajwa » 05 Sep 2024, 03:59
AND ALSO when editing my cms page i cannot add image i add the image it opens a window "Select Image" but there is nothing on that window
Re: STRIPE SETUP
Post by aimeos » 05 Sep 2024, 19:56
bajwa wrote: 05 Sep 2024, 03:59 AND ALSO when editing my cms page i cannot add image i add the image it opens a window "Select Image" but there is nothing on that window
Upload the image in the Media tab first, then add and select the image.
