Importing product images takes too long.
I need to import product images to my Aimeos shop.
I have about 50,000 products inside my Shop, each product should have one of two pictures.
I'm using Aimeos 22.10 inside TYPO3 11.5. I'm importing through the default csv product import with custom mappings (see below).
Linux: Ubuntu 22.04.4 LTS
PHP : 8.2.23
While importing 40 pictures takes just 30 sec, importing 100 doesn't stop running even after two hours.
Which configurations should I check to speed up the import? Is there a faster way to import pictures?
If not, is there a way to set pictures for all product of a category?
Is there a way to log progress or timings?
Could this be a memory Problem? (Looking at the numbers, it shouldn't be. Anyway, I tried lowering the max-size value)
noteable Settings:
Mapping (TypoScript):
PHP : 8.2.23
noteable Settings:
skip-lines = 2
// when importing less than 200 products this should have an effekt?
max-size = 200 // I've also tried the default 1000 but it seems to make no difference.
mapping{
item {
0 = product.code
media {
6 = media.type
13 = media.label
39= media.url
// Example
0: 1463755,
6: "default",
13: "picture",
39: "https://example.org/fileadmin/picture.jpg"
Memory:
total used free shared buff/cache available
Mem: 7923528 2085600 290136 474616 5547792 5157248
Swap: 0 0 0
Re: Importing product images takes too long.
If you import images from external domains, the network latency is usually the biggest source of delays and long import times. You can add timing information for the media import in the aimeos/ai-controller-jobs package here:
https://github.com/aimeos/ai-controller ... #L217-L245
Adding output to the scale() method of the media controller can give you detailed information:
https://github.com/aimeos/aimeos-core/b ... #L182-L208
Note that Aimeos 22.10 is supported only by the ELTS program of the Aimeos company:
https://aimeos.com/support#c427
Thanks for the reply!
After looking at some measurements. I noticed my PHP maximum execution time was set to 30s
I roughly get two products per second now.
Do I have to increase the "maximum execution time" to the time the import takes, even if that would mean raising it to multiple hours or days?
Is there a way to find all images without pictures?
Is there a way to import local images? I tried the absolute /path/to/file.jpeg, but couldn't get it working.aimeos wrote: 04 Sep 2024, 10:37 If you import images from external domains, the network latency is usually the biggest source of delays and long import times. You can add timing information for the media import in the aimeos/ai-controller-jobs package here:
We are currently in the process of upgrading.Note that Aimeos 22.10 is supported only by the ELTS program of the Aimeos company:
You should never execute an importer via a HTTP request. Instead, start importers only via the command line or cronjobs where the max execution time should be unlimited.
The image paths for importing from local file system must be always relative to the virtual file system defined here:
https://github.com/aimeos/aimeos-typo3/ ... hp#L46-L51
I started the Import via the TYPO3 Scheduler. But executed it manually, could this cause my script to depend on the execution time? Because after setting it to a higher value, my execution worked.
What is the recommended TYPO3 way of starting an import? Should I run the Symfony command (JobsCommand) via console?
Thank You for your help!
YesDoku wrote: 06 Sep 2024, 08:08 I started the Import via the TYPO3 Scheduler. But executed it manually, could this cause my script to depend on the execution time? Because after setting it to a higher value, my execution worked.
YesDoku wrote: 06 Sep 2024, 08:08 What is the recommended TYPO3 way of starting an import? Should I run the Symfony command (JobsCommand) via console?
