customer is empty
Muhammad-Nawlo
customer is empty
Post by Muhammad-Nawlo » 09 Sep 2024, 14:06
php 8.1
aimeos-laravel 2024.07
aimeoscom/ai-site 2024.07
Hey thank you for your time,
I have a problem,I am using aimeos headless and nextjs for frontend.
When I logged in locally in my laptop the customer return correctly, but when I deploy the project it is return empty customer
cors config is:
'paths' => ['api/*', 'sanctum/csrf-cookie','default/jsonapi/*','sofiasstores/jsonapi/*','hasnastores/jsonapi/*'],
'allowed_methods' => ['*'],
'allowed_origins' => ['https://hasna.shop','https://sofiasstores.com','http://localhost:3000','http://127.0.0.1:3000'],
'allowed_origins_patterns' => [],
'allowed_headers' => ['*'],
'exposed_headers' => [],
'max_age' => 0,
'supports_credentials' => true,
Re: customer is empty
Post by aimeos » 10 Sep 2024, 08:01
Make sure the Laravel session cookie is sent with each request and the settings are correct if you send it from a different domain.
Muhammad-Nawlo
Post by Muhammad-Nawlo » 10 Sep 2024, 12:31
Thank you,but what do you mean about setting?
Post by aimeos » 11 Sep 2024, 08:19
It depends a bit on the API you are using (React, Apollo, fetch, etc.) but cross-origin request require some special settings:
https://developer.mozilla.org/en-US/doc ... n_requests
