How to order products which are not in stock
claude27
Post by claude27 » 09 Oct 2024, 14:02
I want to create a waiting list for event products. So it would be perfect if the customer could order products which are no longer in stock. At the moment the customer can click on the button "add to basket" but in the basket the number of ordered items is automatically reset to zero, so the customer cann't order.
How can I achieve this? Or what mistake did I make?
Thank you!
(I use Aimeos in a TYPO3 12.4 environment)
Re: How to order products which are not in stock
Post by aimeos » 10 Oct 2024, 07:32
You need to deactivate the "ProductStock" basket plugin in Setup > Plugins of the admin backend.
claude27
Post by claude27 » 22 Oct 2024, 13:42
Thank you! It works now as expected.
