How to get the frontend Configaration value from Payment provider?
mmrtonmoy
Post by mmrtonmoy » 14 Oct 2024, 23:09
I can not get frontend configuration attribute that provide in checkout page.
Aimeos laravel version: "aimeos/aimeos-laravel": "~2024.10",
Laravel: 11
php: 8.2
Environment: windows 10
I use it and the filed is showing in the checkout page perfectly
private array $feConfig = array(
        'aamarpay.mobile' => array(
            'code' => 'aamarpay.mobile',
			'internalcode'=> 'mobile',
			'label'=> 'Phone',
			'type'=> 'string',
			'internaltype'=> 'string',
			'default'=> '',
			'required'=> true
        'novalnetsepa.bic' => array(
			'code' => 'novalnetsepa.bic',
			'internalcode'=> 'bic',
			'label'=> 'BIC code',
			'type'=> 'string',
			'default'=> '',
			'required'=> true
When checkout user can provide there phone number and BIC code but I can not get the value(data) of Phone and BIC inside the process method.
How can I get the value of Phone and BIC code inside the process method or anywhere in the payment provider ?
I tried like this but failed :
$this->getConfigFE($order)['aamarpay.mobile']
My full code is :
<?php
namespace Aimeos\MShop\Service\Provider\Payment;
use Illuminate\Support\Collection;
class AamarPay extends \Aimeos\MShop\Service\Provider\Payment\Base
implements \Aimeos\MShop\Service\Provider\Payment\Iface {
    private array $beConfig = array(
        'aamarpay.StoreID' => array(
			'code' => 'aamarpay.StoreID',
			'internalcode' => 'aamarpay.StoreID',
			'label' => 'Aamarpay Store ID',
            'type' => 'string',
			'default' => '',
			'required' => true,
        'aamarpay.SignatureKey' => array(
			'code' => 'aamarpay.SignatureKey',
			'internalcode' => 'aamarpay.SignatureKey',
			'label' => 'Aamarpay Signature Key',
            'type' => 'string',
			'default' => '',
			'required' => true,
        'aamarpay.testmode' => array(
			'code' => 'aamarpay.testmode',
			'internalcode' => 'aamarpay.testmode',
			'label' => 'Test mode without payments',
			'type' => 'bool',
			'internaltype' => 'boolean',
			'default' => '0',
			'required' => true,
			'label'=> 'Phone',
			'type'=> 'string',
			'default'=> '',
			'required'=> true
			'type'=> 'string',
			'default'=> '',
			'required'=> true
	 * Returns the configuration attribute definitions of the provider to generate a list of available fields and
	 * rules for the value of each field in the administration interface.
	 * @return array List of attribute definitions implementing \Aimeos\Base\Critera\Attribute\Iface
	public function getConfigBE() : array
		return $this->getConfigItems( $this->beConfig );
	 * Checks the backend configuration attributes for validity.
	 * @param array $attributes Attributes added by the shop owner in the administraton interface
	 * @return array An array with the attribute keys as key and an error message as values for all attributes that are
	 * 	known by the provider but aren't valid
	public function checkConfigBE( array $attributes ) : array
		$errors = parent::checkConfigBE( $attributes );
		return array_merge( $errors, $this->checkConfig( $this->beConfig, $attributes ) );
    public function getConfigFE( \Aimeos\MShop\Order\Item\Iface $basket ) : array
		$list = [];
		$feconfig = $this->feConfig;
        try
			$service = $basket->getService( \Aimeos\MShop\Order\Item\Service\Base::TYPE_PAYMENT, 0 );
			foreach( $service->getAttributeItems() as $item )
				if( isset( $feconfig[$item->getCode()] ) ) {
					$feconfig[$item->getCode()]['default'] = $item->getValue();
		catch( \Aimeos\MShop\Order\Exception $e ) {; }
		foreach( $feconfig as $key => $config ) {
			$list[$key] = new \Aimeos\Base\Criteria\Attribute\Standard( $config );
		return $list;
    public function checkConfigFE( array $attributes ) : array
		return $this->checkConfig( $this->feConfig, $attributes );
    public function setConfigFE( \Aimeos\MShop\Order\Item\Service\Iface $orderServiceItem,
		array $attributes ) : \Aimeos\MShop\Order\Item\Service\Iface
		return $orderServiceItem->addAttributeItems( $this->attributes( $attributes, 'payment' ) );
    public function getFullUrl() {
        return ($this->getConfigValue(array('aamarpay.testmode')) === true) ? 'https://sandbox.aamarpay.com/jsonpost.php' : 'https://secure.aamarpay.com/jsonpost.php';
    public function payRequest(array $param) {
        $data = json_encode($param);
        $curl = curl_init();
        curl_setopt_array($curl, array(
        CURLOPT_URL => $this->getFullUrl(),
        CURLOPT_RETURNTRANSFER => true,
        CURLOPT_ENCODING => '',
        CURLOPT_MAXREDIRS => 10,
        CURLOPT_TIMEOUT => 0,
        CURLOPT_FOLLOWLOCATION => true,
        CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1,
        CURLOPT_CUSTOMREQUEST => 'POST',
        CURLOPT_POSTFIELDS =>$data,
        CURLOPT_HTTPHEADER => array(
            'Content-Type: application/json'
        $response = curl_exec($curl);
        curl_close($curl);
       return $response;
    public function process( \Aimeos\MShop\Order\Item\Iface $order,
    array $params = [] ) : ?\Aimeos\MShop\Common\Helper\Form\Iface
    //$total = $order->getPrice()->getValue() + $order->getPrice()->getCosts();
    $storeid = $this->getConfigValue(array('aamarpay.StoreID'));
    $SignatureKey = $this->getConfigValue(array('aamarpay.SignatureKey'));
    if( ( $addresses = $order->getAddress( \Aimeos\MShop\Order\Item\Address\Base::TYPE_DELIVERY ) ) === [] ) {
        $addresses = $order->getAddress( \Aimeos\MShop\Order\Item\Address\Base::TYPE_PAYMENT );
    $addresses = $order->getAddress( type: \Aimeos\MShop\Order\Item\Address\Base::TYPE_PAYMENT );
    $addr = current( $order->getAddress( 'payment' ) );
    $data = [
        'store_id' => $storeid,
        'signature_key' => $SignatureKey,
        'tran_id' => $order->getId(),
        'currency' => $order->getPrice()->getCurrencyId(),
        'desc' => 'Name: ' . $addr->getFirstName() . ' ' . $addr->getLastName() . ' Order id: ' . $order->getId(),
        'cus_name' => $addr->getFirstName() . ' ' . $addr->getLastName(),
        'cus_email' => $addr->getEmail(),
        'cus_phone' => $this->getConfigFE($order)['aamarpay.mobile'],
        'success_url' => $this->getConfigValue( 'payment.url-success' ),
        'fail_url' => $this->getConfigValue( 'payment.url-success' ),
        'cancel_url' => $this->getConfigValue( 'payment.url-success' ),
        'type' => 'json'
    $status = \Aimeos\MShop\Order\Item\Base::PAY_RECEIVED;
    $order->setStatusPayment( $status );
    $this->save( $order );
    return parent::process( $order, $params );
Re: How to get the frontend Configaration value from Payment provider?
Post by aimeos » 15 Oct 2024, 10:07
The values are stored as order service attributes in the basket in your setConfigFE() method. You can get that values later using:
if($service = current($order->getService('payment'))) {
    $attrItems = $service->getAttributeItems();
There are more methods for retrieving service attributes available:
https://github.com/aimeos/aimeos-core/b ... #L151-L175
