Help with Filtering Products Using product.config
Jairus34
Post by Jairus34 » 18 Oct 2024, 07:07
Hi community. I'm trying to filter products based on product.config, but I'm running into some issues. Here’s my current code:
$productManager = \Aimeos\MShop::create( $this->context(), 'product' );
$filter = $productManager->filter();
$filter->add( 'product.config', '==',  ); //What to put here?
$items = $productManager->search( $filter );
Re: Help with Filtering Products Using product.config
Post by aimeos » 21 Oct 2024, 08:43
The product "config" property is just a key/value store which you can't use for filtering. If you nee filtering for your data, use product properties instead:
https://aimeos.org/docs/latest/manual/p ... cteristics
