Extending Aimeos JSON API to Include Custom Customer Fields
Paulus-Ragnarr
Post by Paulus-Ragnarr » 04 Nov 2024, 02:52
Hi Aimeos,
I've added a new column, national_id, to the customer (Users) table following the steps outlined in the documentation:
https://aimeos.org/docs/2024.x/models/extend-managers/
https://aimeos.org/docs/2024.x/models/e ... /#easy-way
https://aimeos.org/docs/2024.x/models/e ... custom-way
I would like to know how to extend the JSON API to include this new field, specifically for the "Change Customer Data" and "Fetch Customer Data" routes. I attempted to add national_id in the request body, but it didn’t update the field in the database.
Are there additional configurations needed to enable this custom field in the API responses and allow it to be updated correctly?
Thanks in advance!
Enviroment: Aimeos-headless
Aimeos version: 2024.07.*
Laravel: 11
Mac OS
Re: Extending Aimeos JSON API to Include Custom Customer Fields
Post by aimeos » 04 Nov 2024, 13:54
This one should be sufficient:
Can you show your code and configuration you've added?
Paulus-Ragnarr
Post by Paulus-Ragnarr » 04 Nov 2024, 23:15
Hello, Here's the codes
Schema
<?php
return array(
    'table' => array(
      'users' => function ( \Aimeos\Upscheme\Schema\Table $table ) {
          $table->string('national_id', 20)->null( true );
          $table->string('provider_id')->null( true );
          $table->string('provider_name', 20)->null( true );
Customer Decorator
<?php
namespace Aimeos\MShop\Product\Manager\Decorator;
 * Manager decorator for Catalog
 * @see https://aimeos.org/docs/2024.x/models/extend-managers/#easy-way
class CustomerDecorator extends \Aimeos\MShop\Common\Manager\Decorator\Base
    private $attr = [
        'national_id' => [
            'internalcode' => 'mcus."national_id"',
            'label' => 'National ID',
            'type' => 'string',
        'provider_id' => [
            'internalcode' => 'mcus."provider_id"',
            'label' => 'Provider ID',
            'type' => 'string',
        'provider_name' => [
            'internalcode' => 'mcus."provider_name"',
            'label' => 'Provider name',
            'type' => 'string',
     * @return array
    public function getSaveAttributes() : array
        return parent::getSaveAttributes() + $this->createAttributes( $this->attr );
     * @param bool $withsub
     * @return array|\Aimeos\Base\Criteria\Attribute\Iface[]
    public function getSearchAttributes( bool $sub = true ) : array
        return parent::getSearchAttributes( $sub ) + $this->createAttributes( $this->attr );
Mshop config
<?php
return [
    'customer' => [
        'manager' => [
            'decorator' => [
                'local' => ['CustomerDecorator']
Post by aimeos » 05 Nov 2024, 15:56
The namespace of your decorator is wrong and must be:
namespace Aimeos\MShop\Customer\Manager\Decorator;
