How to manage customer basket
PaoloLegaspi
Post by PaoloLegaspi » 19 Nov 2024, 05:56
I’m working with Aimeos Headless and JWT, and I’ve run into an issue with user basket items. Since the customer basket is tied to the session, I was wondering if it’s possible to handle these scenarios:
1. Merge or restore a guest basket with the user’s existing basket when they log in.
2. Persist customer’s basket even after they log out or when the session ends.
Any guidance on this would be much appreciated!
Thanks!
Re: How to manage customer basket
Post by aimeos » 22 Nov 2024, 09:05
It's possible when you extend the Laravel/JWT login controller to load the last basket of the customer. The basket is already stored in the database with the ID of the customer if he is logged in.
PaoloLegaspi
Post by PaoloLegaspi » 09 Dec 2024, 11:57
I noticed an issue where, if a client adds products to their basket before logging in, those items don’t carry over after they log in. The basket also doesn’t get linked to the customer’s account. How can I make sure the basket items persist after the user logs in?
Aimeos version: Aimeos Headless 2024.07.*
PHP version: 8.2
Environment: Mac
Post by aimeos » 13 Dec 2024, 12:04
The basket is session based, so make sure you send the correct (same) session cookie value to the server after login. The basket is stored in the database using a "token", which is stored in that session:
https://github.com/aimeos/aimeos-larave ... #L260-L267
Post by aimeos » 13 Dec 2024, 12:16
Regarding the customer ID which isn't added to the basket after login, please update aimeos/ai-controller-frontend to 2024.10.x-dev. This change should improve the situation to assign the customer ID to the basket when customers log in after the basket has been created:
https://github.com/aimeos/ai-controller ... 97eb636048
PaoloLegaspi
Post by PaoloLegaspi » 16 Dec 2024, 02:57
Hello, I just updated to the new version, and it’s now working on our end. Thank you! :D
