How to Filter Discounted Products Using JSON:API?
PaoloLegaspi
Post by PaoloLegaspi » 24 Nov 2024, 10:46
Hey there,
Is it possible to filter products with discounts or rebates using JSON:API routes and queries? If so, could you share how to set that up? Thanks a lot!
Re: How to Filter Discounted Products Using JSON:API?
Post by aimeos » 25 Nov 2024, 11:53
You can't filter for discounted products (products with a value greater than 0.00 for "rebate" in price items) by default because the rebate value isn't added to the index in the mshop_index_price table and there's no search configuration like this in the price index manager: https://github.com/aimeos/aimeos-core/b ... hp#L31-L51
If you can create a PR with the necessary changes, we are happy to merge it.
