woocommerce migration not working for nested categories
whYME
Post by whYME » 04 Dec 2024, 19:21
I'm using aimeos-laravel 2024.10.3 with ai-woocommerce 2024.10.1
Running the WC migration I'm getting a Aimeos\MW\Tree\Exception
No node with ID "571" found.
It's being triggered by WooMigrateCategories, line 60.
I see that what's happening is when it inserts the categories it pulled from WC it's not keeping the existing IDs (term_id in the WP query) instead it's assigning new auto-incremented IDs. So when it hits a record with an existing parent_id (in my case 571) it's erroring out because the parent was assigned a new id, 571 doesn't exist. -and if it did exist it would most likely be the wrong record.
Re: woocommerce migration not working for nested categories
Post by aimeos » 05 Dec 2024, 08:49
So it's already a problem in your Woocommerce data? If yes, fix the data in Woocommerce first and then try the migration again.
whYME
Post by whYME » 05 Dec 2024, 15:11
I'm not sure what you mean by a "problem" in my WooCommerce data? Is this not how WooCommerce is supposed to work?
It seems to me that we should be keeping the existing WooCommerce IDs anyways, not assigning new ones. Presumably anyone migrating from WC has an existing store and will likely have all kinds of compatibility problems if the WC IDs aren't kept.
Post by aimeos » 05 Dec 2024, 16:10
The ID of the category is set to the original Woocommerce ID immediately in the next line with the update() statement as it's not possible in Aimeos to create a category item with an assigned ID in the database:
$item = $manager->insert( $item, $parent?->getId() );
$db2->update( 'mshop_catalog', ['id' => $row['term_id']], ['id' => $item->getId()] );
Can you post the full stack trace of the exception you are encountering?
whYME
Post by whYME » 05 Dec 2024, 16:51
  at vendor/aimeos/aimeos-core/src/MW/Tree/Manager/DBNestedSet.php:702
    698▕                $stmt->bind( 2, 0, \Aimeos\Base\DB\Statement\Base::PARAM_INT );
    699▕                $result = $stmt->execute();
    700▕
    701▕                if( ( $row = $result->fetch() ) === null ) {
  ➜ 702▕                        throw new \Aimeos\MW\Tree\Exception( sprintf( 'No node with ID "%1$d" found', $id ) );
    703▕                }
    704▕
    705▕                return $this->createNodeBase( $row );
    706▕        }
  1   vendor/aimeos/aimeos-core/src/MW/Tree/Manager/DBNestedSet.php:187
      Aimeos\MW\Tree\Manager\DBNestedSet::getNodeById()
  2   vendor/aimeos/aimeos-core/src/MW/Tree/Manager/DBNestedSet.php:243
      Aimeos\MW\Tree\Manager\DBNestedSet::getNode()
  3   vendor/aimeos/aimeos-core/src/MShop/Catalog/Manager/Standard.php:537
      Aimeos\MW\Tree\Manager\DBNestedSet::insertNode()
  4   vendor/aimeos/aimeos-core/src/MShop/Common/Manager/Decorator/Base.php:50
      Aimeos\MShop\Catalog\Manager\Standard::insert()
  5   vendor/aimeos/aimeos-core/src/MShop/Common/Manager/Decorator/Base.php:50
  6   vendor/aimeos/aimeos-core/src/MShop/Common/Manager/Decorator/Base.php:50
      Aimeos\MShop\Common\Manager\Decorator\Base::__call()
  7   vendor/aimeos/aimeos-core/src/MShop/Common/Manager/Decorator/Base.php:50
  8   vendor/aimeos/ai-woocommerce/setup/WooMigrateCategories.php:60
  9   vendor/aimeos/upscheme/src/Up.php:364
      Aimeos\Upscheme\Task\WooMigrateCategories::up()
  10  vendor/aimeos/upscheme/src/Up.php:191
      Aimeos\Upscheme\Up::runTasks()
  11  vendor/aimeos/aimeos-core/Setup.php:84
      Aimeos\Upscheme\Up::up()
  12  vendor/aimeos/aimeos-laravel/src/Command/SetupCommand.php:65
      Aimeos\Setup::up()
  13  vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:36
      Aimeos\Shop\Command\SetupCommand::handle()
  14  vendor/laravel/framework/src/Illuminate/Container/Util.php:43
      Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
  15  vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:95
      Illuminate\Container\Util::unwrapIfClosure()
  16  vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:35
      Illuminate\Container\BoundMethod::callBoundMethod()
  17  vendor/laravel/framework/src/Illuminate/Container/Container.php:694
      Illuminate\Container\BoundMethod::call()
  18  vendor/laravel/framework/src/Illuminate/Console/Command.php:213
      Illuminate\Container\Container::call()
  19  vendor/symfony/console/Command/Command.php:279
      Illuminate\Console\Command::execute()
  20  vendor/laravel/framework/src/Illuminate/Console/Command.php:182
      Symfony\Component\Console\Command\Command::run()
  21  vendor/symfony/console/Application.php:1094
      Illuminate\Console\Command::run()
  22  vendor/symfony/console/Application.php:342
      Symfony\Component\Console\Application::doRunCommand()
  23  vendor/symfony/console/Application.php:193
      Symfony\Component\Console\Application::doRun()
  24  vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:197
      Symfony\Component\Console\Application::run()
  25  artisan:35
      Illuminate\Foundation\Console\Kernel::handle()
At the point the exception is thrown the mshop_catalog table has all the WC parent=0 categories inserted, but with new IDs (and parentid 1) so in this particular case my WC record with term_id=571 has an id of 21 in the mshop_catalog table.
Post by aimeos » 05 Dec 2024, 17:12
Strange. Can you please check why the $db2->update() statement doesn't set the mshop_catalog.id values after insertion to the original Woocommerce IDs?
whYME
Post by whYME » 05 Dec 2024, 22:37
So I'm not sure I understand 100% what's going on, but I was able to get it to work by changing line 37 of WooMigrateCatagories.php from
$db2 = $this->db( 'db-catalog' );
to
$db2 = $this->db( 'db' );
Post by aimeos » 06 Dec 2024, 13:46
How does your "resource" section in your ./config/shop.php looks like?
whYME
Post by whYME » 06 Dec 2024, 15:12
The only db things it has is the "main"
'db' => [
			'adapter' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.driver', 'mysql' ),
			'host' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.host', '127.0.0.1' ),
			'port' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.port', '3306' ),
			'socket' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.unix_socket', '' ),
			'database' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.database', 'forge' ),
			'username' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.username', 'forge' ),
			'password' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.password', '' ),
			'stmt' => config( 'database.default', 'mysql' ) === 'mysql' ? ["SET SESSION sort_buffer_size=2097144; SET NAMES 'utf8mb4'; SET SESSION sql_mode='ANSI'"] : [],
			'limit' => 3, // maximum number of concurrent database connections
			'defaultTableOptions' => [
				'charset' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.charset' ),
				'collate' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.collation' ),
			'driverOptions' => config( 'database.connections.' . config( 'database.default', 'mysql' ) . '.options' ),
and the "db-woocommerce" one I added for the migration.
What I was unsure about is what $this->db( 'db-catalog' ) is supposed to be connecting to. If it's a non-existent db connection shouldn't that throw an error? and if it's the wrong db shouldn't the $db2->update() throw an error for table not found?
Post by aimeos » 06 Dec 2024, 15:18
If "db-catalog" doesn't exist, it falls back to the first database connection. Therefore, your "db" configuration must be always first:
'resource' => [
    'db' => [
    'db-woocommerce' => [
