Linking Custom Domain Manager to Media Domain in JSON:API
Jairus34
Post by Jairus34 » 09 Dec 2024, 02:56
I’ve set up a new domain manager along with a list-type manager to store data with images. Now, I’m wondering if there’s a way to link it to the media domain. I’m using JSON:API.
Could you guide me on how to go about this?
Thanks!
Re: Linking Custom Domain Manager to Media Domain in JSON:API
Post by aimeos » 09 Dec 2024, 10:34
If everything is correctly implemented, you can get the media items attached to your new domain items using "include=media"
Jairus34
Post by Jairus34 » 09 Dec 2024, 11:04
I haven’t created the GET method for JSON:API yet. I’m still figuring out how to attach media items and store them in storage using the POST method in JSON:API.
So far, I’ve created:
1. mshop_trade (main domain)
2. mshop_trade_list
3. mshop_trade_list_type
I’ve also set up the managers for mshop_trade and am currently working on the POST method for JSON:API."
Is there a guide or resource that can help me achieve this? Thank you!
Post by aimeos » 11 Dec 2024, 10:44
The customer JSON:API endpoint has implemented handling POST requests:
https://github.com/aimeos/ai-client-jso ... #L266-L300
To store uploaded files, you should use the upload() method of the media manager:
https://github.com/aimeos/aimeos-core/b ... /Iface.php
Jairus34
Post by Jairus34 » 01 Jan 2025, 03:42
Hi, I created a lists table called Mshop_trade_list to manage relationships for my main domain Mshop_trade. Should I follow the documentation and create a class for Mshop_trade_list as mentioned here: https://aimeos.org/docs/latest/models/c ... ing-domain?
Also, I’m having trouble with the createListItem and getRefItems method. Any ideas on what might be causing the issue?
Post by aimeos » 01 Jan 2025, 10:02
Yes, you need an Iface and a Standard class for a Lists and Type manager. Use the product domain as example:
https://github.com/aimeos/aimeos-core/t ... ager/Lists
Jairus34
Post by Jairus34 » 01 Jan 2025, 10:07
Thank you for your response.
I noticed that the product lists and type manager do not have a getSaveAttributes() function. Just to confirm, does this mean I need to create one similar to the example in the documentation?
namespace Aimeos\MShop\Product\Manager\Test;
class Standard
    extends \Aimeos\MShop\Common\Manager\Base
    implements \Aimeos\MShop\Common\Manager\Iface
    public function getSaveAttributes() : array
        return $this->createAttributes( [
            'parentid' => [
                'type' => 'int',
                'public' => false
            'label' => [
            'status' => [
                'type' => 'int',
            'position' => [
                'type' => 'int',
                'label' => 'Position for sorting'
Post by aimeos » 01 Jan 2025, 10:14
No. Use the product list and list type manager as example. Creating list and type managers is simpler than custom domain managers but not yet documented separately.
Jairus34
Post by Jairus34 » 04 Jan 2025, 10:03
Hi, I have followed the steps and examples, but when I try to use createListItem(), there is an error.
Called unknown method "createListItem" on class "Aimeos\Mshop\Trade\Manager\Standard"
//POST Jsonapi
public function post(ServerRequestInterface $request, ResponseInterface $response): ResponseInterface
        $view = $this->view();
        $context = $this->context();
        try {
            $body = (string) $request->getBody();
            if (($payload = json_decode($body)) === null || !isset($payload->data->attributes)) {
                throw new \Aimeos\Client\JsonApi\Exception('Invalid JSON in body', 400);
            $manager = \Aimeos\MShop::create($context, 'trade');
            $manager->begin();
            $attributes = (array) $payload->data->attributes;
            $item = $manager->create()->fromArray($attributes);
            if (isset($attributes['trade.services']) && is_array($attributes['trade.services'])) {
                foreach ($attributes['trade.services'] as $key => $value) {
                    $listitem = $manager->createListItem();
                    $listitem->setRefId($value)
                        ->setPosition($key);
                    $item->addListItem('services', $listitem);
            $workshop = $manager->save($item);
            $status = 201;
            $manager->commit();
            $view->item = $workshop;
        } catch (\Aimeos\MShop\Exception $e) {
            $manager->rollback();
            $status = 404;
            $view->errors = $this->getErrorDetails($e, 'mshop');
        } catch (\Exception $e) {
            $status = $e->getCode() >= 100 && $e->getCode() < 600 ? $e->getCode() : 500;
            $view->errors = $this->getErrorDetails($e);
        return $response->withHeader('Allow', 'PATCH,POST')
            ->withHeader('Cache-Control', 'no-cache, private')
            ->withHeader('Content-Type', 'application/vnd.api+json')
            ->withBody($view->response()->createStreamFromString($body))
            ->withStatus($status);
//Standard Manager
class Standard
    public function getSaveAttributes(): array
        return $this->createAttributes([
            'domain' => [
                'code' => 'trade.domain',
                'internalcode' => 'mtra."domain"',
                'label' => 'Domain',
                'type' => 'string'
            'full_name' => [
                'code' => 'trade.full_name',
                'internalcode' => 'mtra."full_name"',
                'label' => 'Full Name',
                'type' => 'string'
            'email' => [
                'code' => 'trade.email',
                'internalcode' => 'mtra."email"',
                'label' => 'Email',
                'type' => 'string'
            'phone' => [
                'code' => 'trade.phone',
                'internalcode' => 'mtra."phone"',
                'label' => 'Phone',
                'type' => 'string'
            'info' => [
                'code' => 'trade.info',
                'internalcode' => 'mtra."info"',
                'label' => 'Additional Information',
                'type' => 'string'
            'booking_date' => [
                'code' => 'trade.booking_date',
                'internalcode' => 'mtra."booking_date"',
                'label' => 'Booking Date',
                'type' => 'datetime',
            'agree' => [
                'code' => 'trade.agree',
                'internalcode' => 'mtra."agree"',
                'label' => 'Agree',
                'type' => 'string'
            'status' => [
                'code' => 'trade.status',
                'internalcode' => 'mtra."status"',
                'label' => 'Status',
                'type' => 'string'
    public function create (array $value = []) : \Aimeos\MShop\Trade\Item\Iface
        $value['trade.siteid'] = $value['trade.siteid'] ?? $this->context()->locale()->getSiteId();
        return $this->createItemBase( $value );
    protected function createItemBase( array $values = [] ) : \Aimeos\MShop\Trade\Item\Iface
        return new \Aimeos\MShop\Trade\Item\Standard( $values );
Post by aimeos » 06 Jan 2025, 15:48
Add the Lists decorator to your domain: https://github.com/aimeos/aimeos-core/b ... ct.php#L13
