Multiselect attributes
vp33
Post by vp33 » 18 Dec 2024, 16:06
I didnt notice in demo the posibility to create a multi-select attribute.
Also that multi-select attribute should have the posibility to be updated via import.
And of course to be filterable in front.
Any info here please ?
Ty
Re: Multiselect attributes
Post by aimeos » 18 Dec 2024, 16:09
vp33
Post by vp33 » 19 Dec 2024, 09:17
ty for fast answer but it helps nothing.
1. i allready checked documentantion and you have 0 returns on multislect
2. i found 0 informations about how the TYPES work and I will extend this:
a. there is attribtue, attribute lists, attribute properties in types
b. there is catalog > attributes
How do they work together and where is a detailed documentation on this ?
I allready read this https://aimeos.org/docs/2023.x/config/admin-jqadm/type/ but this is more like for extending than to using the backend.
And in here https://aimeos.org/docs/latest/manual/product-details/ there is no explanation of the types created in 1 section working with 2 section (numbered above).
So my q is the same: how to create a multiselect attrbute that can be selected in backend with multiple values and also to be able to filter it in front end ?
thank you
Post by aimeos » 19 Dec 2024, 15:01
OK, got it. Attribute types with multiple selected entries are currently not supported by products.
To make them possible, you have to adapt this file for allowing multiple selections in the frontend:
https://github.com/aimeos/ai-client-htm ... ribute.php
How the parameters must be passed to the basket is documented here (b_prod[0][attrconfid][id][]: xx):
https://aimeos.org/docs/latest/frontend ... es/#basket
In the backend, you only have to add several config attributes of the same type to the product like shown in the link to the docs.
