Help for accordion Menu
vp33
Post by vp33 » 19 Dec 2024, 11:29
I tried find links in forum regarding accordion menu but I didnt find.
Did anyone implement something like this and can share some know-how / code please ?
Or at least point out wich files will I have to revise and their location.
I am using for now the standalone version and not the Laravel one (where i saw there is a way to easily creat a portable theme).
Thank you
Re: Help for accordion Menu
Post by aimeos » 19 Dec 2024, 11:59
What is an accordion menu? Do you have an example?
Aimeos has a mega-menu if you add the key "css-class" and value "megamenu" in the configuration table of the category root node
vp33
Post by vp33 » 19 Dec 2024, 12:25
Accordion menu is a menu like all the big ecommerce stores have:
check amazon and see 3 lines and ALL.
When you click on it, you can see the categories in a top to bottom format.
Is it mostly called HAMBURGER MENU.
"Aimeos has a mega-menu if you add the key "css-class" and value "megamenu" in the configuration table of the category root node" - I am new to Aimeos and I am not very sure I can follow this without additional info / pics.
Post by aimeos » 19 Dec 2024, 12:37
For the configuration, see: https://admin.demo.aimeos.org/admin/def ... ?locale=en
For a demo, check the "Bestseller" in the menu here: https://laravel.demo.aimeos.org/
vp33
Post by vp33 » 19 Dec 2024, 12:49
1. i noticed that option yet puting the value megamenu to the css-css option doesnt seem to me to make any changes
2. megamenu doesnt solve my demand, the demand is to have a Hamburger Menu like amazon < please check initial demand I sent
Post by aimeos » 19 Dec 2024, 12:56
A hamburger menu is only displayed for small device screens. If you want a drop-down menu, you should adapt the CSS of the catalog-filter-tree nodes and it's children in a customized catalog-filter.css file
vp33
Post by vp33 » 19 Dec 2024, 13:14
in the standalone version of Aimeos is it possible to have custom css files in my project to overwrite/extend the menu in order to achieve that amazon's way of menu - the hamburger ?
becasue making a new theme-folder in /vendor/ is not a good way.
wouldn't I loose the whole folder on updating aimeos if I do a new theme (copying the files from default to a new folder) ?
ty
Post by aimeos » 19 Dec 2024, 14:54
You can adapt the ./public/vendor/shop/themes/default/catalog-filter.css file because it's not overwritten after first installation but you can also add a custom CSS file. You will only notice that you may need to overwrite more existing styles.
