Stock is not decrease
Muhammad-Nawlo
Post by Muhammad-Nawlo » 01 Jan 2025, 22:17
PHP:8.1
aimeos-site:2024.10
aimeos-laravel:2024.10
aimeos-core:2024.10
Hey, How are you doing?
I want to ask you about stock.
My stock is not decreamenting when the order payment status change to authorized (I changed manually).
I tried to clear cache,run jobs (order/service/async),check the database which updated
But the stock was not decrease.
I am using Cash on delivery for payment and custom delivery that has fixed price only (there is no api)
Re: Stock is not decrease
Post by aimeos » 02 Jan 2025, 14:56
You are right, stock level is currently not decreased if you set the payment status of an order to "authorized" manually in the admin backend. We will see how we can implement that safely.
Muhammad-Nawlo
Post by Muhammad-Nawlo » 03 Jan 2025, 11:09
I implement a webhook for my payment gateway
Cause I use nextjs as frontend and laravel aimeos as backend
How can I update status of order and decrease the stock
Post by aimeos » 06 Jan 2025, 15:14
When changing the payment status in the admin backend or from the web hook?
Muhammad-Nawlo
Post by Muhammad-Nawlo » 06 Jan 2025, 18:35
I want to implement both
Post by aimeos » 08 Jan 2025, 13:20
The order manager has an update() method which accepts the order item. It will update stock levels based on the payment status: https://github.com/aimeos/aimeos-core/b ... e.php#L101
