Inquiry: Storing Favorites in Session for Guest Users
Paulus-Ragnarr
Post by Paulus-Ragnarr » 16 Jan 2025, 09:32
Hey Aimeos,
We have a scenario on our site where we want non-logged-in users to be able to add product favorites. Currently, the customer favorites JSON API requires authentication to add favorites, but we’re wondering if it’s possible to implement something like the basket, where favorites could be stored in the session for non-logged-in users as well.
If this is feasible, could you guide us on how to set it up and what resources we should refer to?
Thanks so much!
Aimeos version: Aimeos Headless 2024.10.*
PHP version: 8.2
Environment: Mac
Re: Inquiry: Storing Favorites in Session for Guest Users
Post by aimeos » 16 Jan 2025, 10:05
The pinned product feature is what you are looking for.
Paulus-Ragnarr
Post by Paulus-Ragnarr » 16 Jan 2025, 10:07
Thanks for the reply.
Is this available via JSON API? We are using Json Api Aimeos Headless.
Post by aimeos » 18 Jan 2025, 12:12
Unfortunately not. There's no API for that and you have to create one. If you do, please consider creating a pull request as we would be happy to merge it into the core :-)
