Add product to basekt via custom php command
BeatGurtner
Post by BeatGurtner » 16 Jan 2025, 09:50
i try to add a product to my basket with this code:
I see a success message in postman, but its not added to my basket: http://127.0.0.1:8000/shop/basket
I work with PHP 8.3.14 and aimeos 2024.10 on a mac.
{"status":"success","message":"Product added to cart","basket_info":{"product_count":1,"total_price":"5,544.00","currency":"USD","product_code":"123456","session_id":"T3Fq6X9g8o6D7XOR9rVwlxCmfjVc09qU2XzpHBNi","product_id":"18"}}
<?php
namespace App\Http\Controllers;
use Illuminate\Http\Request;
use Aimeos\Controller\Frontend;
use Aimeos\MShop\Exception as MShopException;
use Illuminate\Support\Facades\View;
class CustomCartController extends Controller
    public function addToCart(Request $request)
        try {
            // Get the context with locale
            $context = app('aimeos.context')->get(false);
            // Set up the locale with currency and language
            $locale = app('aimeos.locale')->get($context, [
                'lang' => 'en',
                'currency' => 'USD'
            $context->setLocale($locale);
            // Validate input
            $productCode = $request->input('product_id');
            $quantity = max(1, (int)$request->input('quantity', 1));
            if (!$productCode) {
                return response()->json([
                    'status' => 'error',
                    'message' => 'Product code is required'
                ], 400);
            // Get product manager
            $productManager = \Aimeos\MShop::create($context, 'product');
            // Create base filter
            $filter = $productManager->filter(true);
            $filter->add('product.code', '==', $productCode);
            $filter->add('product.status', '==', 1);
            // Find the product with all required domains
            $product = $productManager->search(
                $filter,
                ['text', 'price', 'media', 'attribute', 'product', 'catalog', 'stock']
            )->first();
            if (!$product) {
                    'message' => 'Product not found or not active: ' . $productCode
                ], 404);
            // Verify product is in a category
            $listManager = \Aimeos\MShop::create($context, 'product/lists');
            $filter = $listManager->filter(true);
            $filter->add([
                $filter->and([
                    $filter->is('product.lists.domain', '==', 'catalog'),
                    $filter->is('product.lists.parentid', '==', $product->getId()),
                    $filter->is('product.lists.status', '==', 1),
            $listItems = $listManager->search($filter);
            if ($listItems->isEmpty()) {
                // If no category relationship found, try rebuilding the index
                exec('php artisan aimeos:jobs index/rebuild');
                    'message' => 'Product is not associated with any category. Please assign it to a category first.',
                    'debug_info' => [
                        'product_id' => $product->getId(),
                        'product_code' => $product->getCode(),
                ], 400);
            // Get the basket controller
            $basketController = \Aimeos\Controller\Frontend::create($context, 'basket')
                ->setType('default');
            // Add product to basket
            $basketController->addProduct(
                $product,
                $quantity,
                [],             // Variant attributes
                [],             // Config attributes
                [],             // Custom attributes
                'default',      // Stock type
                null            // Site ID
            // Get basket contents for verification
            $basket = $basketController->get();
            $products = $basket->getProducts();
                'status' => 'success',
                'message' => 'Product added to cart',
                'basket_info' => [
                    'product_count' => count($products),
                    'total_price' => number_format($basket->getPrice()->getValue(), 2),
                    'currency' => $basket->getPrice()->getCurrencyId(),
                    'product_code' => $productCode,
                    'session_id' => session()->getId(),
        } catch (MShopException $e) {
                'message' => $e->getMessage(),
                'code' => $e->getCode(),
                'trace' => $e->getTraceAsString()
            ], 400);
        } catch (\Exception $e) {
            ], 500);
Re: Add product to basekt via custom php command
Post by aimeos » 16 Jan 2025, 10:03
There are a few problems in your code.
Use the product ID if possible because it's easier to handle.
filter(true) automatically adds a condition for product.status > 0
            $filter->add([
                $filter->and([
Don't use list managers directly. Instead. Use the product:has() search function of the product manager:
$filter->add($filter->make('product:has', ['catalog']);
But you don't need that at all because it's already checked when you add the product to the basket.
Never execute cronjobs in HTTP requests as they are long lasting operations which will exceed the PHP runtime limit!
                $product,
                $quantity,
                null            // Site ID
You can skip all arguments after "$quantity" because these are also the default values.
Also, make sure that you send the Laravel session cookie along with each request. Otherwise, you always get back a new and empty basket.
