Debug Templates
randomdennis
Debug Templates
Post by randomdennis » 22 Jan 2025, 12:02
Hello, I have a general question about a problem that I keep noticing when updating Aimeos and updating my own template extensions.
As soon as a template e.g. Category List has a faulty call e.g. from an old version of Aimeos, nothing is displayed in the frontend. Typo3 and Aimeos logs also show nothing despite a high log level.
My solution approach is to work my way down in the template with “echo ‘1’;exit;” to see when there is no more output, i.e. the error is in this line.
This is tedious and often misleading.
Am I doing something wrong here or is that just the way it is? If so, isn't there any way to display error messages at the point where the template could be displayed normally, as is the case in pimcore or similar?
Re: Debug Templates
Post by aimeos » 22 Jan 2025, 17:26
You should change the TYPO3 debug settings:
https://docs.typo3.org/m/typo3/referenc ... figuration
randomdennis
Re: Debug Templates
Post by randomdennis » 30 Jan 2025, 14:36
i have this enabled, also via settings.php
Re: Debug Templates
Post by aimeos » 30 Jan 2025, 20:19
randomdennis
Re: Debug Templates
Post by randomdennis » 31 Jan 2025, 15:00
yes also
Re: Debug Templates
Post by aimeos » 03 Feb 2025, 09:17
The problem is that TYPO3 hides displaying errors in the frontend by default and writes it to ./var/log/typo3_....log instead.
randomdennis
Re: Debug Templates
Post by randomdennis » 11 Mar 2025, 12:52
mhm i still get no errors, not even in typo3 log. Debug activated, Display Errors on
Re: Debug Templates
Post by aimeos » 11 Mar 2025, 13:38
Maybe you need to reconfigure the TYPO3 exception handler
randomdennis
Re: Debug Templates
Post by randomdennis » 12 Mar 2025, 16:27
We have it set to Debug. Maybe i override something with my Extention, as we do also not have any entries for the aimeos tasks such as Scale etc. in the planner at aimeos as soon as our Extention is activated. So far, I have briefly deactivated our Extention to create the tasks.
