[SOLVED] Howto add extentions (instructions for newbe)
ЕвгенияСемихова(ИПСемиховаЕ.А.)
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 22 Jan 2025, 20:08
Have order 3 extentions. How I can understand - I neet to add to composer config "composer.json" new repositories. Ok, I have add to the end. What I need to do next?
Can't find any informations at officical documentation.
Last edited by ЕвгенияСемихова(ИПСемиховаЕ.А.) on 24 Jan 2025, 16:57, edited 1 time in total.
Debian 12, PHP 8.3, Server 1 = Aimeos 2024.10.13, Server 2 = ES 8.17.1
life is full of many new and interesting things
Re: Howto add extentions (instructions)
Post by aimeos » 23 Jan 2025, 09:32
This is very basic stuff when working with composer (getcomposer.org). Just run "composer update" to install the extensions. Afterwards, run "php artisan aimeos:setup" to update the database.
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 23 Jan 2025, 20:16
Dear Aimeos, I have read many informations about composer, now start understand what is this and for what it needed. I also have download Open Server Panel (analog of local's LAMP) and install Aimeos at virtual localhost.
I put composer to 'myshop' catalog and start "composer update":
Nothing to install, update or remove
I understand that I need to use my login/password for authentification at composer repository, but I can't understand how.
Can you write step by step? I think it will be help for many newbie like me.
P.S.: Otherwise, we figured out the internal system pretty quickly and we like Aimeos more and more.
Post by aimeos » 24 Jan 2025, 13:27
Edit the "requires" section of your existing composer.json and add the extensions you want to install like this:
	"aimeoscom/ai-<name>": "~2024.10",
e.g.:
	"aimeoscom/ai-sites": "~2024.10",
	"aimeoscom/ai-customergroups": "~2024.10",
Then, run "composer update" and it will ask you for a user name (e-mail address you've used when buying the extensions) and the password (sent to you in a separate e-mail after buying the first time).
Finally, run this command to update the database:
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 24 Jan 2025, 15:15
[SOLVED] How to add extentions to Aimeos (Instruction for newbe):
To add extensions to Aimeos, you must:
1) open the "composer file.json" (in the root of default catalog "my shop") and add the necessary packages to the "requires" section:
Attention: pay special attention to the syntax, after the last line you need to put a comma and add your lines, otherwise composer will scold:
2) If you have done everything correctly, run the "composer update" command and, upon request, specify the login and password provided to you at the first sale:
3) after the installation of the applications is completed, do not forget to run the store update command:
Thank you very much for your helping and so interesting system! And I'll go to the next step of preparing of our project.
