[SOLVED] Something wrong with translating
ЕвгенияСемихова(ИПСемиховаЕ.А.)
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 25 Feb 2025, 07:32
New trouble (I think):
1) I try to write two names at English and Russian:
2) Press "Save" and I see only one write:
What I do: just finish "composer req aimeos/ai-controller-jobs:2024.10.x-dev" and import 20k items.
The same picture at ideal items (from the first time add - all three translation languages were added earlier and now, if you start changing, the last language set replaces the previous one. That is, there were 3 translations, I change the third one and after saving there are no translations left - only the very first and the third).
Where can I look about this issue?
Last edited by ЕвгенияСемихова(ИПСемиховаЕ.А.) on 27 Feb 2025, 11:45, edited 1 time in total.
Debian 12, PHP 8.3, Server 1 = Aimeos 2024.10.13, Server 2 = ES 8.17.1
life is full of many new and interesting things
Re: Something wrong with translating
Post by aimeos » 25 Feb 2025, 10:19
We can't reproduce the issue. Can you please post the output of "composer show" and record a video of what you are exactly doing?
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 25 Feb 2025, 13:23
aimeos/ai-admin-graphql            2024.10.3             Aimeos Admin GraphQL API extension
aimeos/ai-admin-jqadm              2024.10.12            Aimeos VueJS+Bootstrap admin backend
aimeos/ai-admin-jsonadm            2024.10.3             Aimeos JSON admin API for backend
aimeos/ai-client-html              2024.10.5             Aimeos standard HTML frontend
aimeos/ai-client-jsonapi           2024.10.5             Aimeos frontend JSON REST API
aimeos/ai-cms-grapesjs             2024.10.6             Aimeos GrapesJS CMS extension
aimeos/ai-controller-frontend      2024.10.3             Aimeos business controller logic for frontend
aimeos/ai-controller-jobs          2024.10.x-dev 8e3d70f Aimeos job controllers for long running tasks
aimeos/ai-laravel                  2024.10.3             Laravel adapter for Aimeos e-commerce integration
aimeos/aimeos-base                 2024.10.4             Aimeos base layer for abstracting from host environments
aimeos/aimeos-core                 2024.10.13            Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel              2024.10.3             Cloud native, API first Laravel eCommerce package with integrated AI for ultra-fast online shops, marketpla...
aimeos/macro                       1.0.2                 Customize classes using closures
aimeos/map                         3.11.0                Easy and elegant handling of PHP arrays as array-like collection objects similar to jQuery and Laravel Coll...
aimeos/upscheme                    1.2.0                 Database schema upgrades made easy
aimeoscom/ai-elastic               2024.10.3             Aimeos ElasticSearch integration for #gigacommerce
aimeoscom/ai-sites                 2024.10.6             Aimeos hierarchical sites extension for market places and complex setups
brick/math                         0.12.1                Arbitrary-precision arithmetic library
carbonphp/carbon-doctrine-types    3.2.0                 Types to use Carbon in Doctrine
dflydev/dot-access-data            3.0.3                 Given a deep data structure, access data by dot notation.
doctrine/dbal                      4.2.2                 Powerful PHP database abstraction layer (DBAL) with many features for database schema introspection and man...
doctrine/deprecations              1.1.4                 A small layer on top of trigger_error(E_USER_DEPRECATED) or PSR-3 logging with options to disable all depre...
doctrine/inflector                 2.0.10                PHP Doctrine Inflector is a small library that can perform string manipulations with regard to upper/lowerc...
doctrine/lexer                     3.0.1                 PHP Doctrine Lexer parser library that can be used in Top-Down, Recursive Descent Parsers.
dragonmantank/cron-expression      3.4.0                 CRON for PHP: Calculate the next or previous run date and determine if a CRON expression is due
egulias/email-validator            4.0.3                 A library for validating emails against several RFCs
elasticsearch/elasticsearch        7.17.2                PHP Client for Elasticsearch
enshrined/svg-sanitize             0.21.0                An SVG sanitizer for PHP
ezimuel/guzzlestreams              3.1.0                 Fork of guzzle/streams (abandoned) to be used with elasticsearch-php
ezimuel/ringphp                    1.3.0                 Fork of guzzle/RingPHP (abandoned) to be used with elasticsearch-php
fakerphp/faker                     1.24.1                Faker is a PHP library that generates fake data for you.
filp/whoops                        2.17.0                php error handling for cool kids
fruitcake/php-cors                 1.3.0                 Cross-origin resource sharing library for the Symfony HttpFoundation
graham-campbell/result-type        1.1.3                 An Implementation Of The Result Type
guzzlehttp/guzzle                  7.9.2                 Guzzle is a PHP HTTP client library
guzzlehttp/promises                2.0.4                 Guzzle promises library
guzzlehttp/psr7                    2.7.0                 PSR-7 message implementation that also provides common utility methods
guzzlehttp/uri-template            1.0.4                 A polyfill class for uri_template of PHP
hamcrest/hamcrest-php              2.0.1                 This is the PHP port of Hamcrest Matchers
intervention/gif                   4.2.1                 Native PHP GIF Encoder/Decoder
intervention/image                 3.11.1                PHP image manipulation
laminas/laminas-diactoros          3.5.0                 PSR HTTP Message implementations
laravel/breeze                     2.3.4                 Minimal Laravel authentication scaffolding with Blade and Tailwind.
laravel/framework                  11.43.2               The Laravel Framework.
laravel/pint                       1.21.0                An opinionated code formatter for PHP.
laravel/prompts                    0.3.5                 Add beautiful and user-friendly forms to your command-line applications.
laravel/sail                       1.41.0                Docker files for running a basic Laravel application.
laravel/sanctum                    4.0.8                 Laravel Sanctum provides a featherweight authentication system for SPAs and simple APIs.
laravel/serializable-closure       2.0.3                 Laravel Serializable Closure provides an easy and secure way to serialize closures in PHP.
laravel/tinker                     2.10.1                Powerful REPL for the Laravel framework.
league/commonmark                  2.6.1                 Highly-extensible PHP Markdown parser which fully supports the CommonMark spec and GitHub-Flavored Markdown...
league/config                      1.2.0                 Define configuration arrays with strict schemas and access values with dot notation
league/flysystem                   3.29.1                File storage abstraction for PHP
league/flysystem-local             3.29.0                Local filesystem adapter for Flysystem.
league/mime-type-detection         1.16.0                Mime-type detection for Flysystem
league/uri                         7.5.1                 URI manipulation library
league/uri-interfaces              7.5.0                 Common interfaces and classes for URI representation and interaction
mockery/mockery                    1.6.12                Mockery is a simple yet flexible PHP mock object framework
monolog/monolog                    3.8.1                 Sends your logs to files, sockets, inboxes, databases and various web services
myclabs/deep-copy                  1.13.0                Create deep copies (clones) of your objects
nesbot/carbon                      3.8.6                 An API extension for DateTime that supports 281 different languages.
nette/schema                       1.3.2                 📐 Nette Schema: validating data structures against a given Schema.
nette/utils                        4.0.5                 🛠  Nette Utils: lightweight utilities for string & array manipulation, image handling, safe JSON encodin...
nikic/php-parser                   5.4.0                 A PHP parser written in PHP
nunomaduro/collision               8.6.1                 Cli error handling for console/command-line PHP applications.
nunomaduro/termwind                2.3.0                 Its like Tailwind CSS, but for the console.
nyholm/psr7                        1.8.2                 A fast PHP7 implementation of PSR-7
phar-io/manifest                   2.0.4                 Component for reading phar.io manifest information from a PHP Archive (PHAR)
phar-io/version                    3.2.1                 Library for handling version information and constraints
phpoption/phpoption                1.9.3                 Option Type for PHP
phpunit/php-code-coverage          11.0.8                Library that provides collection, processing, and rendering functionality for PHP code coverage information.
phpunit/php-file-iterator          5.1.0                 FilterIterator implementation that filters files based on a list of suffixes.
phpunit/php-invoker                5.0.1                 Invoke callables with a timeout
phpunit/php-text-template          4.0.1                 Simple template engine.
phpunit/php-timer                  7.0.1                 Utility class for timing
phpunit/phpunit                    11.5.9                The PHP Unit Testing framework.
psr/cache                          3.0.0                 Common interface for caching libraries
psr/clock                          1.0.0                 Common interface for reading the clock.
psr/container                      2.0.2                 Common Container Interface (PHP FIG PSR-11)
psr/event-dispatcher               1.0.0                 Standard interfaces for event handling.
psr/http-client                    1.0.3                 Common interface for HTTP clients
psr/http-factory                   1.1.0                 PSR-17: Common interfaces for PSR-7 HTTP message factories
psr/http-message                   2.0                   Common interface for HTTP messages
psr/log                            3.0.2                 Common interface for logging libraries
psr/simple-cache                   3.0.0                 Common interfaces for simple caching
psy/psysh                          0.12.7                An interactive shell for modern PHP.
ralouphie/getallheaders            3.0.3                 A polyfill for getallheaders.
ramsey/collection                  2.0.0                 A PHP library for representing and manipulating collections.
ramsey/uuid                        4.7.6                 A PHP library for generating and working with universally unique identifiers (UUIDs).
react/promise                      3.2.0                 A lightweight implementation of CommonJS Promises/A for PHP
sebastian/cli-parser               3.0.2                 Library for parsing CLI options
sebastian/code-unit                3.0.2                 Collection of value objects that represent the PHP code units
sebastian/code-unit-reverse-lookup 4.0.1                 Looks up which function or method a line of code belongs to
sebastian/comparator               6.3.0                 Provides the functionality to compare PHP values for equality
sebastian/complexity               4.0.1                 Library for calculating the complexity of PHP code units
sebastian/diff                     6.0.2                 Diff implementation
sebastian/environment              7.2.0                 Provides functionality to handle HHVM/PHP environments
sebastian/exporter                 6.3.0                 Provides the functionality to export PHP variables for visualization
sebastian/global-state             7.0.2                 Snapshotting of global state
sebastian/lines-of-code            3.0.1                 Library for counting the lines of code in PHP source code
sebastian/object-enumerator        6.0.1                 Traverses array structures and object graphs to enumerate all referenced objects
sebastian/object-reflector         4.0.1                 Allows reflection of object attributes, including inherited and non-public ones
sebastian/recursion-context        6.0.2                 Provides functionality to recursively process PHP variables
sebastian/type                     5.1.0                 Collection of value objects that represent the types of the PHP type system
sebastian/version                  5.0.2                 Library that helps with managing the version number of Git-hosted PHP projects
spatie/backtrace                   1.7.1                 A better backtrace
spatie/error-solutions             1.1.3                 This is my package error-solutions
spatie/flare-client-php            1.10.1                Send PHP errors to Flare
spatie/ignition                    1.15.1                A beautiful error page for PHP applications.
spatie/laravel-ignition            2.9.1                 A beautiful error page for Laravel applications.
staabm/side-effects-detector       1.0.5                 A static analysis tool to detect side effects in PHP code
symfony/clock                      7.2.0                 Decouples applications from the system clock
symfony/console                    7.2.1                 Eases the creation of beautiful and testable command line interfaces
symfony/css-selector               7.2.0                 Converts CSS selectors to XPath expressions
symfony/deprecation-contracts      3.5.1                 A generic function and convention to trigger deprecation notices
symfony/error-handler              7.2.3                 Provides tools to manage errors and ease debugging PHP code
symfony/event-dispatcher           7.2.0                 Provides tools that allow your application components to communicate with each other by dispatching events ...
symfony/event-dispatcher-contracts 3.5.1                 Generic abstractions related to dispatching event
symfony/finder                     7.2.2                 Finds files and directories via an intuitive fluent interface
symfony/http-foundation            7.2.3                 Defines an object-oriented layer for the HTTP specification
symfony/http-kernel                7.2.3                 Provides a structured process for converting a Request into a Response
symfony/mailer                     7.2.3                 Helps sending emails
symfony/mime                       7.2.3                 Allows manipulating MIME messages
symfony/polyfill-ctype             1.31.0                Symfony polyfill for ctype functions
symfony/polyfill-intl-grapheme     1.31.0                Symfony polyfill for intl's grapheme_* functions
symfony/polyfill-intl-idn          1.31.0                Symfony polyfill for intl's idn_to_ascii and idn_to_utf8 functions
symfony/polyfill-intl-normalizer   1.31.0                Symfony polyfill for intl's Normalizer class and related functions
symfony/polyfill-mbstring          1.31.0                Symfony polyfill for the Mbstring extension
symfony/polyfill-php80             1.31.0                Symfony polyfill backporting some PHP 8.0+ features to lower PHP versions
symfony/polyfill-php83             1.31.0                Symfony polyfill backporting some PHP 8.3+ features to lower PHP versions
symfony/polyfill-uuid              1.31.0                Symfony polyfill for uuid functions
symfony/process                    7.2.0                 Executes commands in sub-processes
symfony/psr-http-message-bridge    7.2.0                 PSR HTTP message bridge
symfony/routing                    7.2.3                 Maps an HTTP request to a set of configuration variables
symfony/service-contracts          3.5.1                 Generic abstractions related to writing services
symfony/string                     7.2.0                 Provides an object-oriented API to strings and deals with bytes, UTF-8 code points and grapheme clusters in...
symfony/translation                7.2.2                 Provides tools to internationalize your application
symfony/translation-contracts      3.5.1                 Generic abstractions related to translation
symfony/uid                        7.2.0                 Provides an object-oriented API to generate and represent UIDs
symfony/var-dumper                 7.2.3                 Provides mechanisms for walking through any arbitrary PHP variable
symfony/yaml                       7.2.3                 Loads and dumps YAML files
tecnickcom/tcpdf                   6.8.2                 TCPDF is a PHP class for generating PDF documents and barcodes.
theseer/tokenizer                  1.2.3                 A small library for converting tokenized PHP source code into XML and potentially other formats
tijsverkoyen/css-to-inline-styles  2.3.0                 CssToInlineStyles is a class that enables you to convert HTML-pages/files into HTML-pages/files with inline...
vlucas/phpdotenv                   5.6.1                 Loads environment variables from `.env` to `getenv()`, `$_ENV` and `$_SERVER` automagically.
voku/portable-ascii                2.0.3                 Portable ASCII library - performance optimized (ascii) string functions for php.
webmozart/assert                   1.11.0                Assertions to validate method input/output with nice error messages.
webonyx/graphql-php                15.19.1               A PHP port of GraphQL reference implementation
https://youtu.be/j2x1UvJkC8A
P.S.: there are no any errors at logs
P.P.S.: at first video is not owner seller. Ok, I've record new video of create new item's card:
https://youtu.be/ll8ykddx4Wo
upd: I have change shop.php to SQL DB and do the same step for create new item:
All is perfect. I think trouble in ES
Post by aimeos » 26 Feb 2025, 16:38
Thank you for your help! We were able to reproduce the problem and have fixed it in aimeoscom/ai-elastic:2024.10.x-dev.
We've also fixed a bug in aimeoscom/ai-customergroups:2024.10.x-dev which caused the index/customer/attribute problem.
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 26 Feb 2025, 17:55
Yes, now all working fine! Thanks, dear! This is 5 stars for your works!
Q: at this time two part of Aimeos in .dev line (at my server). Is this fixes will be at major packed (for example, at 2015.04 , like ubuntu)? And I can use complex update Aimeos and automaticaly get that, what I have now at .dev package? All be ok at april updates? Or will be need to select by hands?
To ALL: use command:
php composer req aimeoscom/ai-elastic:2024.10.x-dev
Yeehaa! And we are moving on to the next stage of fascinating knowledge and the intriguing launch of the Aimeos-based system. There is still a lot of work in the settings, in the backend, and in the frontend, but the main catalog will already be in the amount of several million items.
Post by aimeos » 27 Feb 2025, 11:17
ЕвгенияСемихова(ИПСемиховаЕ.А.) wrote: 26 Feb 2025, 17:55 Q: at this time two part of Aimeos in .dev line (at my server). Is this fixes will be at major packed (for example, at 2015.04 , like ubuntu)? And I can use complex update Aimeos and automaticaly get that, what I have now at .dev package? All be ok at april updates? Or will be need to select by hands?
There will be a new minor release soon for 2024.10 soon so there will be no need to change anything on your side.
