[SOLVED] Can't save category (in ElasticSearch)
ЕвгенияСемихова(ИПСемиховаЕ.А.)
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 28 Feb 2025, 15:04
Hi, the same proublem, now with category:
create (or edit) item - choose "Category":
and press save, but after reload there nothing:
I think it's the same toruble like with text in ES: [SOLVED] Something wrong with translating
Last edited by ЕвгенияСемихова(ИПСемиховаЕ.А.) on 28 Feb 2025, 16:24, edited 1 time in total.
Debian 12, PHP 8.3, Server 1 = Aimeos 2024.10.13, Server 2 = ES 8.17.1
life is full of many new and interesting things
Re: Can't save category (in ElasticSearch)
Post by aimeos » 28 Feb 2025, 16:14
It works as expected in our test setup but there was a bugfix recently. Can you please make sure you have the latest package versions installed by executing "composer up"?
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 28 Feb 2025, 16:24
yes, now all work fine, thanks
