[SOLVED] Howto delete item by artisan? (clear all DB in ES)
- ЕвгенияСемихова(ИПСемиховаЕ.А.)
I have another small problem: I deleted all the products and it turned out that the products themselves were deleted first, and then unrelated groupings ("select" type) remained. I fixed one of these "lost" bundles by re-uploading related products. But one record remained unconnected.
And I can't change anything - this product was created manually. Please tell me how can I use the command like:
to delete a specific product?
php artisan aimeos:job "delete/product" <ID>
Last edited by ЕвгенияСемихова(ИПСемиховаЕ.А.) on 03 Mar 2025, 11:52, edited 2 times in total.
Debian 12, PHP 8.3, Server 1 = Aimeos 2024.10.13, Server 2 = ES 8.17.1
life is full of many new and interesting things
Re: Howto delete item by artisan?
I have create new csv file with only this item's ID and set it to default type - now I've delete all items.
But any way, can I use direct command by artisan?
And my second question: I have load and delete total near 150'000 items (for tests). Now I have delete all. For index not bad this first item's test manipulations? Old IDs will rewrite? What about old ID after delete from ElasticSearch? It's free again? Or somewhere stored?
Or it is better to total new reinstall Aimeos and ElasticSearch servers? For clean start?
Last edited by ЕвгенияСемихова(ИПСемиховаЕ.А.) on 03 Mar 2025, 10:33, edited 1 time in total.
There's no possibility to delete products from the command line.
Your product is from a different site (the yellow border on the lef shows that) and therefore, you are not able to delete it. Switch to the site were you have created it, and there you can delete it.
Just delete the ES index and run the setup again if you want to remove all (test) products:ЕвгенияСемихова(ИПСемиховаЕ.А.) wrote: 03 Mar 2025, 10:32 Or it is better to total new reinstall Aimeos and ElasticSearch servers? For clean start?
curl -X DELETE <host>:9200/<index>
php artisan aimeos:setup
I know about yellow border - it is good idea, but I try to delete from superadmin. Any way, now all is good. Superadmin can delete any items.aimeos wrote: 03 Mar 2025, 10:33 There's no possibility to delete products from the command line.
Thanks a lot!!!Just delete the ES index and run the setup again if you want to remove all (test) products:
To All:
1) Delete item's indexes at ElasticSearch (command send from Aimeos server):
curl -k --user elastic:PASSWORD -X DELETE http://192.168.0.4:9200/aimeosCode: Select all
curl -k --user elastic:PASSWORD -X DELETE http://192.168.0.4:9200/aimeos_stock3) and after that send:
php artisan aimeos:setupDebian 12, PHP 8.3, Server 1 = Aimeos 2024.10.13, Server 2 = ES 8.17.1
