How to make the site search always global?
DNK
Post by DNK » 13 Mar 2025, 09:46
Now, if I am inside a category, the search works inside this category. What do I need to do to make the search work everywhere and always globally for all products?
Aimeos 2024.10.3 + Laravel 11, PHP 8.2, MySql8.0, Nginx, Ubuntu 22.04.5 LTS
Re: How to make the site search always global?
Post by aimeos » 15 Mar 2025, 11:00
DNK
Post by DNK » 17 Mar 2025, 11:40
Doesn't work:
Search inside category:
Global searching:
Post by aimeos » 17 Mar 2025, 17:24
Sorry, this wasn't the correct setting. There's one named very similarly:
https://aimeos.org/docs/2024.x/config/c ... e-search_1
But it's not enabled by default so it's not the reason why products are only searched within the current category.
The reason is that the f_catid parameter is included in the URL if it's available here:
https://github.com/aimeos/ai-client-htm ... y.php#L104
So you can overwrite the template and remove f_catid from the list of parameters and then it should work.
