How to hide unused brands (and attributes) at filters block (at front of category)
ЕвгенияСемихова(ИПСемиховаЕ.А.)
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 19 Mar 2025, 12:59
Have: a form for searching and filtering when you are in a category. If there are a lot of parameters of characteristics (as well as brands), then all of them are displayed in the filtering field:
Please tell me how to most effectively hide unused brand positions (characteristics) in this category?
Check total pcs?
Debian 12, PHP 8.3, Server 1 = Aimeos 2024.10.13, Server 2 = ES 8.17.1
life is full of many new and interesting things
Re: How to hide unused brands (and attributes) at filters block (at front of category)
Post by aimeos » 21 Mar 2025, 07:56
Can you have a look into your browser console if there's a JS error? At least the attributes are normally hidden by default when there are no products available for that combination.
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 23 Mar 2025, 16:22
No any errors at, for example, category: IGBT on radiodar.market
This is very interesting - I wouldn't ask a question or ask for help if I hadn't checked on another new test setup radiodar.shop (not general, so without ES, only simple DB):
What can I check else, dear?
Post by aimeos » 26 Mar 2025, 08:23
For attributes, the items without counts are disabled here:
https://github.com/aimeos/ai-client-htm ... ter.js#L31
For suppliers (brands), it's done here:
https://github.com/aimeos/ai-client-htm ... ter.js#L60
Can you check what happens on your side there?
Post by ЕвгенияСемихова(ИПСемиховаЕ.А.) » 26 Mar 2025, 13:16
I checked: both sections of the code have no differences (I have not reached this place before and have not made any changes.):
/* Autocomplete 1590fe0 https://github.com/kraaden/autocomplete (MIT License) */
!function(e,t){"object"==typeof exports&&"undefined"!=typeof module?module.exports=t():"function"==typeof define&&define.amd?define(t):(e="undefined"!=typeof globalThis?globalThis:e||self).autocomplete=t()}(this,(function(){"use strict";return function(e){var t,n,o=document,i=e.container||o.createElement("div"),r=i.style,f=navigator.userAgent,l=~f.indexOf("Firefox")&&~f.indexOf("Mobile"),s=e.debounceWaitMs||0,a=e.preventSubmit||!1,u=e.disableAutoSelect||!1,d=l?"input":"keyup",c=[],p="",v=2,g=e.showOnFocus,m=0;if(void 0!==e.minLength&&(v=e.minLength),!e.input)throw new Error("input undefined");var h=e.input;function E(){n&&window.clearTimeout(n)}function w(){return!!i.parentNode}function y(){var e;m++,c=[],p="",t=void 0,(e=i.parentNode)&&e.removeChild(i)}function L(){for(;i.firstChild;)i.removeChild(i.firstChild);var n=function(e,t){var n=o.createElement("div");return n.textContent=e.label||"",n};e.render&&(n=e.render);var f=function(e,t){var n=o.createElement("div");return n.textContent=e,n};e.renderGroup&&(f=e.renderGroup);var l=o.createDocumentFragment(),s="#9?$";if(c.forEach((function(o){if(o.group&&o.group!==s){s=o.group;var i=f(o.group,p);i&&(i.className+=" group",l.appendChild(i))}var r=n(o,p);r&&(r.addEventListener("click",(function(t){e.onSelect(o,h),y(),t.preventDefault(),t.stopPropagation()})),o===t&&(r.className+=" selected"),l.appendChild(r))})),i.appendChild(l),c.length<1){if(!e.emptyMsg)return void y();var a=o.createElement("div");a.className="empty",a.textContent=e.emptyMsg,i.appendChild(a)}i.parentNode||o.body.appendChild(i),function(){if(w()){r.height="auto",r.width=h.offsetWidth+"px";var t,n=0;f(),f(),e.customize&&t&&e.customize(h,t,i,n)}function f(){var e=o.documentElement,i=e.clientTop||o.body.clientTop||0,f=e.clientLeft||o.body.clientLeft||0,l=window.pageYOffset||e.scrollTop,s=window.pageXOffset||e.scrollLeft,a=(t=h.getBoundingClientRect()).top+h.offsetHeight+l-i,u=t.left+s-f;r.top=a+"px",r.left=u+"px",(n=window.innerHeight-(t.top+h.offsetHeight))<0&&(n=0),r.top=a+"px",r.bottom="",r.left=u+"px",r.maxHeight=n+"px"}}(),function(){var e=i.getElementsByClassName("selected");if(e.length>0){var t=e[0],n=t.previousElementSibling;if(n&&-1!==n.className.indexOf("group")&&!n.previousElementSibling&&(t=n),t.offsetTop<i.scrollTop)i.scrollTop=t.offsetTop;else{var o=t.offsetTop+t.offsetHeight,r=i.scrollTop+i.offsetHeight;o>r&&(i.scrollTop+=o-r)}}}()}function b(){w()&&L()}function T(){b()}function x(e){e.target!==i?b():e.preventDefault()}function C(t){for(var n=t.which||t.keyCode||0,o=0,i=e.keysToIgnore||[38,13,27,39,37,16,17,18,20,91,9];o<i.length;o++){if(n===i[o])return}n>=112&&n<=123&&!e.keysToIgnore||40===n&&w()||S(0)}function k(n){var o=n.which||n.keyCode||0;if(38===o||40===o||27===o){var i=w();if(27===o)y();else{if(!i||c.length<1)return;38===o?function(){if(c.length<1)t=void 0;else if(t===c[0])t=c[c.length-1];else for(var e=c.length-1;e>0;e--)if(t===c[e]||1===e){t=c[e-1];break}}():function(){if(c.length<1&&(t=void 0),t&&t!==c[c.length-1]){for(var e=0;e<c.length-1;e++)if(t===c[e]){t=c[e+1];break}}else t=c[0]}(),L()}return n.preventDefault(),void(i&&n.stopPropagation())}13===o&&(t&&(e.onSelect(t,h),y()),a&&n.preventDefault())}function N(){g&&S(1)}function S(o){var i=++m,r=h.value,f=h.selectionStart||0;r.length>=v||1===o?(E(),n=window.setTimeout((function(){e.fetch(r,(function(e){m===i&&e&&(p=r,t=(c=e).length<1||u?void 0:c[0],L())}),o,f)}),0===o?s:0)):y()}function D(){setTimeout((function(){o.activeElement!==h&&y()}),200)}return i.className="autocomplete "+(e.className||""),r.position="absolute",i.addEventListener("mousedown",(function(e){e.stopPropagation(),e.preventDefault()})),i.addEventListener("focus",(function(){return h.focus()})),h.addEventListener("keydown",k),h.addEventListener(d,C),h.addEventListener("blur",D),h.addEventListener("focus",N),window.addEventListener("resize",T),o.addEventListener("scroll",x,!0),{destroy:function(){h.removeEventListener("focus",N),h.removeEventListener("keydown",k),h.removeEventListener(d,C),h.removeEventListener("blur",D),window.removeEventListener("resize",T),o.removeEventListener("scroll",x,!0),E(),y()}}}}));
 * Catalog filter actions
AimeosCatalogFilter = {
	MIN_INPUT_LEN: 3,
	meta: null,
	 * Attribute filter counts
	async loadAttributeCounts() {
		$('.catalog-filter-attribute[data-counturl]').each(async (idx, node) => {
			await fetch($(node).data('counturl')).then(response => {
				return response.json();
			}).then(data => {
				$('.attribute-lists li.attr-item', node).each(function(idx, item) {
					const itemId = $(item).data( "id" );
					if(data[itemId]) {
						$(".attr-name", item).append('&nbsp;' + '<span class="attr-count">' + data[itemId] + '</span>');
					} else {
						$(item).addClass("disabled");
				$('.attribute-lists .attr-count', node).each((idx, el) => {
					$(el).closest("fieldset.attr-sets").show();
	 * Supplier filter counts
	async loadSupplierCounts() {
		$('.catalog-filter-supplier[data-counturl]').each(async (idx, node) => {
			}).then(data => {
				$('.supplier-lists li.attr-item', node).each(function(idx, item) {
					if(data[itemId]) {
					} else {
						$(item).addClass( 'disabled' );
	 * Tree filter counts
	async loadTreeCounts() {
		$('.catalog-filter-tree[data-counturl]').each(async (idx, node) => {
			}).then(data => {
				$('.cat-item', node).each(function(idx, item) {
					const id = $(item).data("id");
					if(data[id]) {
						$('[data-id="' + id + '"] > .item-links > a.cat-link, [data-id="' + id + '"] > .item-links > a.name').append('<span class="cat-count">' + data[id] + '</span>');
					} else if( $(item).hasClass("nochild") ) {
	 * Mega menu
	onMenuHover() {
		const $dropdowns = $('.level-1 > .cat-item');
		$dropdowns.on('mouseover', ev => {
			var $this = $(ev.currentTarget);
			if ($this.prop('hoverTimeout')){
				$this.prop('hoverTimeout', clearTimeout($this.prop('hoverTimeout')));
			$this.prop('hoverIntent', setTimeout(() => {
				$this.addClass('hover');
		}).on('mouseleave', ev => {
			if ($this.prop('hoverIntent')){
				$this.prop('hoverIntent', clearTimeout($this.prop('hoverIntent')));
			$this.prop('hoverTimeout', setTimeout(() => {
				$this.removeClass('hover');
		// For touch devices
		window.matchMedia('(min-width: 991px)').addEventListener('change', ev => {
			if (ev.matches) {
				$dropdowns.each((idx, el) => {
					const $this = $(el);
					el.addEventListener('touchstart', function(e) {
						if (e.touches.length === 1){
							e.stopPropagation();
							if(!$this.hasClass('hover')) {
								if(e.target === this || e.target.parentNode === this) {
									e.preventDefault();
								$dropdowns.removeClass('hover');
								document.addEventListener('touchstart', closeDropdown = function(ev) {
									ev.stopPropagation();
									document.removeEventListener('touchstart', closeDropdown);
					}, false);
	 * Show category offscreen menu
	onShowCategories() {
		$(".catalog-filter-tree .menu").on('click', () => {
			$('.catalog-filter-tree .zeynep').addClass('opened');
			$('.catalog-filter-tree .aimeos-overlay-offscreen').addClass('show');
	 * Hide category offscreen menu
	onHideCategories() {
		$(".catalog-filter-tree .close").on('click', () => {
			$('.catalog-filter-tree .zeynep').removeClass('opened');
			$('.catalog-filter-tree .aimeos-overlay-offscreen').removeClass('show');
	 * Autocompleter for quick search
	onLoadSearch() {
		$(".catalog-filter-search .value").each((idx, el) => {
			const url = $(el).data("url");
			let cache = {} // workaround for re-rendering on Swiffy slider animation
			autocomplete({
				input: el,
				debounceWaitMs: 200,
				minLength: AimeosCatalogFilter.MIN_INPUT_LEN,
				fetch: async function(text, update) {
					await fetch(url.replace('_term_', encodeURIComponent(text))).then(response => {
					}).then(data => {
						update(data);
				render: function(item, value) {
					if(!cache[value]) {
						cache = {}; cache[value] = {};
					if(!cache[value][item.label]) {
						cache[value][item.label] = $(item.html.trim()).get(0);
					return cache[value][item.label];
	 * Registers events for the catalog filter search input reset
	onResetSearch() {
		$(".catalog-filter-search .value").on("keyup", ev => {
			const val = $(ev.currentTarget).val() !== "" ? "visible" : "hidden";
			$(".reset .symbol", $(ev.currentTarget).closest(".catalog-filter-search")).css("visibility", val);
		$(".catalog-filter-search .reset").on("click", ev => {
			const input = $(ev.currentTarget).parents(".catalog-filter-search").find(".value");
			$(".symbol", ev.currentTarget).css("visibility", "hidden");
			input[0].focus();
			input.val("");
			return false;
	 * Sets up the form checks
	onCheckForm() {
		$(".catalog-filter form").on("submit", ev => {
			let result = true;
			$("input.value", ev.currentTarget).each((idx, el) => {
				const input = $(el);
				if(input.val() !== '' && input.val().length < AimeosCatalogFilter.MIN_INPUT_LEN) {
					if(input.has(".search-hint").length === 0) {
						const node = $('<div class="search-hint">' + input.data("hint") + '</div>');
						const pos = node.position();
						node.css("left", pos.left).css("top", pos.top);
						node.delay(3000).fadeOut(1000, () => {
							node.remove();
						$(".catalog-filter-search", ev.currentTarget).after(node);
					result = false;
			return result;
	 * Toggles the attribute filters if hover isn't available
	onToggleAttribute() {
		$('.catalog-filter-attribute').on("click", '.header-name', ev => {
			$(".attribute-lists", $(ev.currentTarget).closest(".catalog-filter-attribute")).each((idx, el) => {
				slideToggle(el, 300);
	onToggleAttributes() {
		$(".catalog-filter-attribute .attribute-lists legend").on("click", ev => {
			$(".attr-list", $(ev.currentTarget).closest("fieldset.attr-sets")).each((idx, el) => {
	 * Submits the form when clicking on filter attribute names or counts
	onSubmitAttribute() {
		$(".catalog-filter-attribute li.attr-item").on("click", ev => {
			const input = $("input", ev.currentTarget);
			input.prop("checked", !input.prop("checked"));
			$(ev.currentTarget).closest(".catalog-filter form")[0].submit();
			return false;
	 * Syncs the price input field and slider
	onSyncPrice() {
		$(".catalog-filter-price").on("input", ".price-high", ev => {
			$(".price-slider", $(ev.currentTarget).closest(".catalog-filter-price")).val($(ev.currentTarget).val());
		$(".catalog-filter-price").on("input", ".price-slider", ev => {
			$(".price-high", $(ev.currentTarget).closest(".catalog-filter-price")).val($(ev.currentTarget).val());
	 * Toggles the price filters if hover isn't available
	onTogglePrice() {
		$('.catalog-filter-price').on("click", '.header-name', ev => {
			$(".price-lists", $(ev.currentTarget).closest(".catalog-filter-price")).each((idx, el) => {
	 * Toggles the search filters if hover isn't available
	onToggleSearch() {
		$('.catalog-filter-search').on("click", '.header-name', ev => {
			$(".search-lists", $(ev.currentTarget).closest(".catalog-filter-search")).each((idx, el) => {
	 * Search for suppliers
	 onSearchSuppliers() {
		const self = this;
		const update = (data, ev) => {
			const list = $('.attr-list', $(ev.currentTarget).closest('.supplier-lists'));
			const prototype = $('.prototype', list);
			$('.result', list).remove();
			for(let entry of (data.data || []).reverse()) {
				let item = prototype.clone().removeClass('disabled').addClass('result');
				$('.attr-name', item).attr('for', 'sup-' + entry['id']);
				$('.attr-name span', item).text(entry['attributes']['supplier.label']);
				$('.attr-item', item).attr('id', 'sup-' + entry['id']).attr('value', entry['id']).removeAttr('disabled');
				list.prepend(item.data('id', entry['id']).removeClass('prototype'));
		const search = Aimeos.debounce(async ev => {
			const val = $(ev.currentTarget).val();
			if(typeof self.meta === 'object' && self.meta['resources'] && self.meta['resources']['supplier']
				&& val.length >= AimeosCatalogFilter.MIN_INPUT_LEN) {
				const url = new URL(self.meta['resources']['supplier']);
				let params = {};
				let args = {
					filter: {
						'~=': {'supplier.label': val}
					sort: 'supplier.position,supplier.label'
				if(self.meta.prefix) { // returned from OPTIONS call
					params[self.meta.prefix] = args;
				} else {
					params = args;
				url.search = url.search ? url.search + '&' + window.param(params) : '?' + window.param(params);
				await fetch(url).then(response => {
				}).then(data => {
					update(data, ev);
		$(".catalog-filter-supplier .supplier-lists").on('input', '.search', ev => {
			this.setupMeta($(ev.currentTarget).closest('.catalog-filter').data('jsonurl'));
			search(ev);
	 * Submits the form when clicking on filter supplier names or counts
	onSubmitSupplier() {
		$(".catalog-filter-supplier").on("click", 'li.attr-item', ev => {
			return false;
	 * Toggles the supplier filters if hover isn't available
	onToggleSupplier() {
		$('.catalog-filter-supplier').on("click", '.header-name', ev => {
			$(".supplier-lists", $(ev.currentTarget).closest(".catalog-filter-supplier")).each((idx, el) => {
	 * Initializes the meta object from OPTIONS request
	 * @param {String} url
	async setupMeta(url) {
		if(url && !this.meta) {
			this.meta = {};
			await fetch(url, {method: 'OPTIONS'}).then(response => {
			}).then(data => {
				this.meta = data['meta'] || null;
	 * Initialize the catalog filter actions
	init() {
		if(this.once) return;
		this.once = true;
		this.onMenuHover();
		this.onShowCategories();
		this.onHideCategories();
		this.onSyncPrice();
		this.onTogglePrice();
		this.onSubmitAttribute();
		this.onToggleAttribute();
		this.onToggleAttributes();
		this.onSearchSuppliers();
		this.onSubmitSupplier();
		this.onToggleSupplier();
		this.onLoadSearch();
		this.onResetSearch();
		this.onToggleSearch();
		this.onCheckForm();
		this.loadAttributeCounts();
		this.loadSupplierCounts();
		this.loadTreeCounts();
$(function() {
	AimeosCatalogFilter.init();
I also followed your link to the demo of the site (you sent it to me on November 26, 2024) and if you select the "default" theme there, then the brand with zero quantity of goods will also not be hidden:
P.S.: at Berlin theme also don't hide:
So, what can I do now?
Post by aimeos » 29 Mar 2025, 14:00
Disabled items only get another color by default. If you want to hide them completely, you need to change the CSS to "display:none" here: https://github.com/aimeos/ai-client-htm ... ss#L33-L36
