Help Needed: Admin Panel Not Accessible After Enabling Multi-Site and Shop Registration (Aimeos 2024)
hussain.h.ff32
Post by hussain.h.ff32 » 15 Apr 2025, 14:50
Hello Aimeos Team,
I’ve recently installed the latest 2024 version of Aimeos on my server. After setting things up successfully, I added a new site and enabled both multi-language and multi-shop support, including shop registration.
Everything worked fine initially, but after signing out from the admin panel, I can no longer access it. The login page loads, but once I try to sign in, it either redirects incorrectly or doesn't log me in properly.
Here’s a quick summary of my setup:
Aimeos Version: 2024.x
Changes Made: Enabled multi-site, multi-language, shop registration
Problem: Admin panel not accessible after logout; cannot sign back in
Any guidance or fix would be appreciated. Let me know if you need additional logs or config info.
Thanks in advance!
Re: Help Needed: Admin Panel Not Accessible After Enabling Multi-Site and Shop Registration (Aimeos 2024)
Post by aimeos » 15 Apr 2025, 21:40
These problems are all related to your wrong ./config/shop.php file you've posted in your other thread.
