Help for creating the first product guide
warmjaijai
Post by warmjaijai » 16 Jun 2016, 10:37
following the creating your first product guide
product is created but the price does not show. (trying to attach the screenshots here but failed) what can possibly go wrong? I added the price and saved already but it just doesn't show. I associate the photo it worked, but just the price. Please help thanks!
warmjaijai
naddy
Re: Help for creating the first product guide
Post by naddy » 16 Jun 2016, 12:11
Can you tell me the fields you filled for the price?
Did you use the standard-Currency?
Post by aimeos » 16 Jun 2016, 12:36
I would look into the same direction as naddy asked.
There's most probably a currency mismatch between the currency you've used in the product price and the default currency in the first site/language/currency combination in the Locale tab of the expert mode admin interface.
