Renaming Locale Site
warmjaijai
Post by warmjaijai » 16 Jun 2016, 10:54
I was trying to test how to make a new site.
Before doing that, I rename "Default" site to other name and since then the extadm no longer working with the following errer.... please help
Exception in Standard.php line 126:
Site for code "default" not found
at Standard->bootstrap('default', '', '', true)
at call_user_func_array(array(object(Standard), 'bootstrap'), array('default', '', '', true)) in Base.php line 51
at Base->__call('bootstrap', array('default', '', '', true)) in Context.php line 181
at Context->getLocale(object(Standard)) in Context.php line 99
at Context->get() in Support.php line 47
at Support->checkGroup('2', 'admin') in AuthServiceProvider.php line 31
at AuthServiceProvider->App\Providers\{closure}(object(User))
at call_user_func_array(object(Closure), array(object(User))) in Gate.php line 268
at Gate->callAuthCallback(object(User), 'admin', array()) in Gate.php line 243
at Gate->raw('admin', array()) in Gate.php line 218
at Gate->authorize('admin', array()) in AuthorizesRequests.php line 22
at ExtadmController->authorize('admin') in ExtadmController.php line 40
at ExtadmController->indexAction(object(Request))
at call_user_func_array(array(object(ExtadmController), 'indexAction'), array(object(Request))) in Controller.php line 80
at Controller->callAction('indexAction', array(object(Request))) in ControllerDispatcher.php line 146
at ControllerDispatcher->call(object(ExtadmController), object(Route), 'indexAction') in ControllerDispatcher.php line 94
at ControllerDispatcher->Illuminate\Routing\{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in Pipeline.php line 52
at Pipeline->Illuminate\Routing\{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in Pipeline.php line 102
at Pipeline->then(object(Closure)) in ControllerDispatcher.php line 96
at ControllerDispatcher->callWithinStack(object(ExtadmController), object(Route), object(Request), 'indexAction') in ControllerDispatcher.php line 54
at ControllerDispatcher->dispatch(object(Route), object(Request), 'Aimeos\Shop\Controller\ExtadmController', 'indexAction') in Route.php line 174
at Route->runController(object(Request)) in Route.php line 140
at Route->run(object(Request)) in Router.php line 724
at Router->Illuminate\Routing\{closure}(object(Request))
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in Authenticate.php line 28
at Authenticate->handle(object(Request), object(Closure))
at call_user_func_array(array(object(Authenticate), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 136
at Pipeline->Illuminate\Pipeline\{closure}(object(Request))
at call_user_func(object(Closure), object(Request)) in Pipeline.php line 32
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in VerifyCsrfToken.php line 64
at VerifyCsrfToken->handle(object(Request), object(Closure))
at call_user_func_array(array(object(VerifyCsrfToken), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 136
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in ShareErrorsFromSession.php line 49
at ShareErrorsFromSession->handle(object(Request), object(Closure))
at call_user_func_array(array(object(ShareErrorsFromSession), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 136
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in StartSession.php line 62
at StartSession->handle(object(Request), object(Closure))
at call_user_func_array(array(object(StartSession), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 136
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in AddQueuedCookiesToResponse.php line 37
at AddQueuedCookiesToResponse->handle(object(Request), object(Closure))
at call_user_func_array(array(object(AddQueuedCookiesToResponse), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 136
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in EncryptCookies.php line 59
at EncryptCookies->handle(object(Request), object(Closure))
at call_user_func_array(array(object(EncryptCookies), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 136
at Pipeline->then(object(Closure)) in Router.php line 726
at Router->runRouteWithinStack(object(Route), object(Request)) in Router.php line 699
at Router->dispatchToRoute(object(Request)) in Router.php line 675
at Router->dispatch(object(Request)) in Kernel.php line 246
at Kernel->Illuminate\Foundation\Http\{closure}(object(Request))
at Pipeline->Illuminate\Routing\{closure}(object(Request)) in CheckForMaintenanceMode.php line 44
at CheckForMaintenanceMode->handle(object(Request), object(Closure))
at call_user_func_array(array(object(CheckForMaintenanceMode), 'handle'), array(object(Request), object(Closure))) in Pipeline.php line 136
at Pipeline->then(object(Closure)) in Kernel.php line 132
at Kernel->sendRequestThroughRouter(object(Request)) in Kernel.php line 99
at Kernel->handle(object(Request)) in index.php line 53
Re: Renaming Locale Site
Post by aimeos » 16 Jun 2016, 12:27
You can add sites on the command line or in the host application but you need to keep the "default" site for now. This will change in the next version.
warmjaijai
Post by warmjaijai » 16 Jun 2016, 15:13
then anyway i can revert that action ?
thanks for your reply!
warmjaijai
Post by warmjaijai » 16 Jun 2016, 15:19
or someewhere i can amend the name back? coz all the extadm paths i assess appear to be the same error page.
Post by aimeos » 16 Jun 2016, 16:12
Either you can change the code back to "default" in the database table "mshop_locale_site" or you run the Aimeos setup again which will create a new "default" site.
warmjaijai
Post by warmjaijai » 17 Jun 2016, 04:18
for setting up Aimeos again, does that mean i just do the exact same procedures described in the documents Installation - Install the Aimeos package again and that will do?
Thanks!
warmjaijai
Post by warmjaijai » 17 Jun 2016, 04:35
Tried to use
php artisan aimeos:setup default
or without default
then now i tried to login with my admin account and then enter http://127.0.0.1:8000/extadm
it gives me this error...
HttpException in Handler.php line 107:
This action is unauthorized.
at Handler->render(object(Request), object(AuthorizationException)) in Handler.php line 48
at Handler->render(object(Request), object(AuthorizationException)) in Pipeline.php line 80
at Pipeline->handleException(object(Request), object(AuthorizationException)) in Pipeline.php line 54
Post by aimeos » 17 Jun 2016, 08:17
You have to login first. Always use http://127.0.0.1:8000/admin as entry point
