how to customize the default, footer etc ..
hussain.h.ff32
Post by hussain.h.ff32 » 12 May 2025, 13:20
am trying to customize the footer , header , and home page slider for the default theme also where to change the slider images because the slider is not showing in the cms
Re: how to customize the default, footer etc ..
Post by aimeos » 13 May 2025, 05:05
The footer is part of the base Blade template and the header is a combination of code from the same template and the output of some HTML client components: https://github.com/aimeos/aimeos-larave ... .blade.php
You can override that template in your application like described here:
https://aimeos.org/docs/latest/laravel/ ... -templates
The main slider is from the catalog/home component:
https://github.com/aimeos/ai-client-htm ... e/body.php
Overriding the HTML client templates is documented here:
https://aimeos.org/docs/latest/frontend ... templates/
