Service provider problem
dala
Post by dala » 31 May 2025, 13:49
I am testing out Aimeos and trying to write my own payment-provider extension.
I am looking following the documentation here https://aimeos.org/docs/2024.x/providers/service/ when trying to register some paymentdata, and I am copying the following code:
$orderServiceItem = $order->getService( 'payment' );
$orderServiceItem->addAttributeItems( $this->attributes( $attributes ), 'myprovider' );
However, $order->getService() returns an array of payment-services, so when calling $orderServiceItem->addAttributeItems, like it shows in the documentation, I get an exception since $orderServiceItem is an array and not an object.
Instead, I have to call $orderServiceItem[0]->addAttributeItems.
First, is there some error in the documentation or is there something I am missing?
Second, since $order->getService( 'payment' ) returns an array, I guess its possible to register multiple payment-servies on each order. How do I know which is the correct one?
Re: Service provider problem
Post by aimeos » 01 Jun 2025, 07:21
This is an error in the docs and you should use current() or reset() to get the first order service item in the array if you are sure there's only one. We will fix that in the docs, thanks for the hint!
