TYPO3 Language navigation problem
- MarjanCvetko
I'm using LanguageMenuProcessor for language menu on the site (used in bootstrap_package):
And then I'm rendering dropdown menu like that:
This is supposed to be the standard way to do it in TYPO3, but I'm facing some problems on single product pages, it renders the translation URL as href="/en/product" without the parameters like that href="/en/product/d/demo-product/0".
I've noticed that inside LanguageMenuProcessor class (/typo3/sysext/frontend/Classes/DataProcessing/LanguageMenuProcessor.php) in prepareConfiguration() function where its setups $paramsToExclude I'm getting the following parameters as exclusion:
My best guess is that those parameters should be included, but i don't know why its excluding it.
Anyone else had that problem before? How do I get it to pass Aimeos parameters as well?
40 = TYPO3\CMS\Frontend\DataProcessing\LanguageMenuProcessor
40 {
languages = {$page.theme.language.languageValue}
as = languagenavigation
<ul class="dropdown-menu">
<f:for each="{languagenavigation}" as="language">
<f:if condition="{language.available}">
<li>
<a class="dropdown-item" href="{language.link}">
<div class="paragraphs-description color-text-brand"><f:format.case mode="upper">{language.twoLetterIsoCode}</f:format.case></div>
</a>
</li>
</f:if>
</f:for>
</ul>
0 = "ai[action]"
1 = "ai[controller]"
2 = "ai[d_name]"
3 = "ai[d_pos]"
4 = "id"
Re: TYPO3 Language navigation problem
You should add "typolink.addQueryString = untrusted" parameter for your language menu.
Have a look at the following link:
https://docs.typo3.org/m/typo3/referenc ... uerystring
