[PHP 8.3.12] [Windows] Form has no style
MuhammadAnnys
Post by MuhammadAnnys » 18 Jul 2025, 02:57
[PHP 8.3.12] [Windows] I just install the latest aomei, the landing page is fine, but when i open the login and register page it look like in the attached file
https://imagekit.io/public/share/idefvb ... bfce760d21https://imagekit.io/public/share/idefvb ... 0dc5e85fce
i follow the install step from the github, then i got this warning
Can't resolve '@tailwindcss/forms' in '...\vendor\laravel\breeze\stubs\default'
i tried installing the node, then npm run dev, but still the same
Re: [PHP 8.3.12] [Windows] Form has no style
Post by aimeos » 21 Jul 2025, 13:54
Thank you for your bug report!
The problem is fixed and a new version has been released now.
If you don't want to install Aimeos from scratch (because the files of the Laravel project are not updated if you run "composer update"), you need to:
1.) Replace the file in your app with the content from Github: https://github.com/laravel/laravel/blob ... ss/app.css
2.) Run "npm update"
3.) Run "npm run build"
Afterwards, new CSS/JS bundle files are generated in your ./public/build/ directory
MuhammadAnnys
Post by MuhammadAnnys » 22 Jul 2025, 07:45
Thank you, it works now
