Questions about facets
matish
Post by matish » 22 Nov 2025, 22:22
I am trying to figure out how facets work over the API.
In general they work, but I would like to limit the facet options that are applicable to the subselection of products.
How can I achieve that?
Now I am using a query, which returns 6 products out of 13 products:
https://aimeos.priit.yt.lan/jsonapi/product?include=attribute%2Cmedia%2Cprice%2Cproduct%2Cproduct%2Fproperty%2Ctext%2Ccatalog%2Csupplier%2Cstock%2Cproperty%2Cproduct%2Fproperty%2Ftype%2Cattribute%2Ftype&page%5Blimit%5D=6&page%5Boffset%5D=0
This query result returns me under 'included' the attributes that are visible on this image:
The problem is that there are more facets available on the next page (such as Manufacturer = HP and so on...).
How can I get full list of available facets that take into account all the filters but exclude paging?
That one I resolved with aggregation (http://localhost:8000/jsonapi/product?aggregate=index.attribute.id)
matish
Re: Questions about facets
Post by matish » 22 Nov 2025, 23:50
Another thing that came up:
Consider the following query:
https://aimeos.priit.yt.lan/jsonapi/product?include=attribute,media,price,product,product/property,text,catalog,supplier,stock,property,product/property/type,attribute/type
&page[limit]=6
&page[offset]=0
&filter[f_optid][0]=14
&filter[f_optid][1]=11
&filter[f_optid][2]=16
&filter[f_optid][3]=17
Here are the explanations for each attribute ID:
14 = color.black
11 = color.white
16 = manufacturer.dell
17 = manufacturer.hp
I would like to select all results where (manufacturer.dell OR manufacturer.hp) AND (color.white OR color.black).
How can I make a query that would achieve that? The query that I have above does not have AND condition in the middle.
Post by aimeos » 24 Nov 2025, 08:59
matish wrote: 22 Nov 2025, 23:50 I would like to select all results where (manufacturer.dell OR manufacturer.hp) AND (color.white OR color.black).
Use "f_oneid" instead:
https://aimeos.org/docs/latest/frontend ... attributes
matish
Post by matish » 24 Nov 2025, 13:48
I did try with that, but that one seems to result in a query:
where (manufacturer.dell OR manufacturer.hp) OR (color.white OR color.black).
But I need:
Post by aimeos » 24 Nov 2025, 13:53
Please have a look at the linked documentation. The f_oneid requires a different filter structure:
filter[f_oneid][color][]=...
matish
Post by matish » 25 Nov 2025, 06:48
aimeos wrote: 24 Nov 2025, 13:53 Please have a look at the linked documentation. The f_oneid requires a different filter structure:
Sorry about the confusion. I took another look and got it working now. Thanks!
&page[limit]=6
&page[offset]=0
&filter[f_oneid][color][0]=13
&filter[f_oneid][vendor][0]=16
&filter[f_oneid][vendor][1]=17
matish
Post by matish » 25 Nov 2025, 08:41
I would like to use min-price...max-price facet too. Is it possible to know what is the minimum and maximum price for the current subselection of products excluding paging?
Post by aimeos » 26 Nov 2025, 13:15
This wasn't possible up to now. The "aimeos/ai-client-jsonapi:2025.10.x-dev" branch contains the changes to use:
/jsonapi/product?aggregate=price:min
/jsonapi/product?aggregate=price:max
Can you give it a try?
matish
Post by matish » 26 Nov 2025, 13:38
aimeos wrote: 26 Nov 2025, 13:15 This wasn't possible up to now. The "aimeos/ai-client-jsonapi:2025.10.x-dev" branch contains the changes to use:
Thanks! It works.
But there is another problem that I am creating right here. I am using HTMX for the UI and it returns full HTML of the page fragment under investigation. For that single HTML fragment I need to make 4 API requests + 2 extra from the post above + some extra if I implement category filtration as well. This amount of requests is a bit too much in my opinion.
Maybe you know a good way to solve it.
Load all possible facets
1) /jsonapi/attribute?include=media,text,attribute/type
Filter all products
2) /jsonapi/product?include=attribute,media,price,product,product/property,text,catalog,supplier,stock,property,product/property/type,attribute/type&page[limit]=6&page[offset]=6&filter[f_oneid][vendor][0]=15&filter[f_oneid][vendor][1]=16
Read out all facet counts
3) /jsonapi/product?include=attribute,media,price,product,product/property,text,catalog,supplier,stock,property,product/property/type,attribute/type&filter[f_oneid][vendor][0]=15&filter[f_oneid][vendor][1]=16&aggregate=index.attribute.id
Read out all category counts
4) /jsonapi/product?include=attribute,media,price,product,product/property,text,catalog,supplier,stock,property,product/property/type,attribute/type&filter[f_oneid][vendor][0]=15&filter[f_oneid][vendor][1]=16&aggregate=index.catalog.id
Post by aimeos » 26 Nov 2025, 13:49
matish wrote: 26 Nov 2025, 13:38
This is static and needs to be loaded only once, so you can cache it.
All others depend on the user action and you can only perform the requests in parallel.
