16.4.3 Update Script SQL Error (mshop_product_list_type)
jfr
Post by jfr » 12 Jul 2016, 09:25
Running the extension managers update script i receive the following error. How can i fix that constraint issue?
Migrate suppliercode in mshop_product
Executing statement "INSERT INTO "mshop_product_list" ("parentid", "siteid", "typeid", "domain", "refid", "config", "status", "ctime", "mtime", "editor")
		 SELECT p."id", p."siteid", (SELECT t."id" FROM "mshop_product_list_type" t WHERE t."siteid" = p."siteid" AND t."domain" = 'supplier' AND t."code" = 'default'), 'supplier', s."id", '[]', 1, NOW(), NOW(), 'setup:ProductMigrateSupplier'
		 FROM "mshop_supplier" s JOIN "mshop_product" p ON p."suppliercode" = s."code"" failed: SQLSTATE[23000]: Integrity constraint violation: 1452 Cannot add or update a child row: a foreign key constraint fails ("INSTANCENAME"."mshop_product_list", CONSTRAINT "fk_msproli_typeid" FOREIGN KEY ("typeid") REFERENCES "mshop_product_list_type" ("id") ON DELETE CASCADE ON UPDATE CASCADE)
Re: 16.4.3 Update Script SQL Error (mshop_product_list_type)
Post by aimeos » 12 Jul 2016, 16:05
From which version did you upgrade?
jfr
Post by jfr » 21 Jul 2016, 14:29
i think 2.4.2
jfr
Post by jfr » 03 Aug 2016, 15:54
any idea where i should have a look into?
Post by aimeos » 05 Aug 2016, 17:38
After the error occurs, is there an entry in your mshop_product_list_type table with
- domain: 'supplier'
- code: 'default'
- label: 'Standard'
- status: 1
Post by aimeos » 06 Aug 2016, 12:12
Can you try this version and tell us if it works?
https://aimeos.org/fileadmin/download/a ... 1-pre2.zip
jfr
Post by jfr » 08 Aug 2016, 14:39
thanks, on it - ill let you know shortly if it worked
jfr
Post by jfr » 08 Aug 2016, 15:20
The update now went through smoothly. Thanks a lot!
One small issue is left: the new backend dashboard throws "Error Price can not be added. Currency ID "" of price item and currently used currency ID "EUR" does not match."
Post by aimeos » 09 Aug 2016, 11:24
jfr wrote: One small issue is left: the new backend dashboard throws "Error Price can not be added. Currency ID "" of price item and currently used currency ID "EUR" does not match."
Seems like there's no locale record (site/language/currency) available
