Catalog tree
earosb
Catalog tree
Post by earosb » 02 Sep 2016, 14:13
Hi there!
I have a catalog tree that i created from backend admin, I need to show the same tree in frontend but when i search all categories the hasChildren function always return false. This is part of my code
$manager = \Aimeos\MShop\Factory::createManager( $context, 'catalog' );
$categories = $manager->searchItems($search);
foreach ($categories as $category) {
    if ( $category->hasChildren() ) {
        // code stuff...
I'm using typo3 7.6.10, extbase and Aimeos 16.4.3
Thanks in advance
Re: Catalog tree
Post by aimeos » 02 Sep 2016, 14:18
Well single items returned by searchItems() don't have children. Use the getTree() method of the catalog manager instead to get a tree of nodes instead.
earosb
Re: Catalog tree
Post by earosb » 02 Sep 2016, 18:59
aimeos wrote:Well single items returned by searchItems() don't have children. Use the getTree() method of the catalog manager instead to get a tree of nodes instead.
Thank you Mr. Aimeos, you are a genius!
