Pagination broken
gilbertsoft
Pagination broken
Post by gilbertsoft » 30 Jan 2017, 10:31
since version 2017.01 pagination on catalog list seems to be broken. page 0 of 2 is shown and if I switch to the second page the following error: Oops, an error occurred! Code: 20170130112303c476ea5c
Is this already corrected in the newest sources?
Regards
Simon
gilbertsoft
Re: Pagination broken
Post by gilbertsoft » 30 Jan 2017, 13:03
Two bugs found at body-default.php, the last 2 params pointed to listProduct instead listPage:
$pagination = $this->partial(
$this->config( 'client/html/catalog/lists/partials/pagination', 'catalog/lists/pagination-default.php' ),
array(
'params' => $params,
'total' => $this->get( 'listProductTotal', 0 ),
'current' => $this->get( 'listPageCurr', 0 ),
'size' => $this->get( 'listPageSize', 48 )
But the error on the second page remains. Are there any hints on debugging, say finding the point of this error fast?
Fixes will be pushed to github as always.
Post by aimeos » 30 Jan 2017, 16:23
What's the latest entry in log file stored in typo3temp/logs/? There you will most probably find a meaningful explanation of what did go wrong.
gilbertsoft
Post by gilbertsoft » 30 Jan 2017, 20:15
I always forget the logfiles, I only looked at the interal logs at the BE ;-( Thanks for the hint! Corrections are uploaded
Post by aimeos » 30 Jan 2017, 23:15
Never mind ;-)
Instead, we would like to give you a really big "thank you" for all your efforts and the great job you did!
