Missing pages and bread crumb path
KarstenSoll
Post by KarstenSoll » 08 Mar 2017, 10:01
Hello!
first of all I’ve got the same problem like some other users with the local and the currency. Which is fixed in your pre-release of version (17.3.0-pre5). – So far so good! But I’ve also downloaded your prepared page tree (Aimeos-pages_two-columns_2.1.4). It includes some Content-Elements that are pointing to a needed page that doesn't exist. For example the “List page of Catalogue” (Listenseite des Katalogs) which might be the starting page of the shop, I guess.
And on the page “confirm”: Here the plugin needs a “page for product downloads” (Seite für Produktdownloads), that is not present in you page tree. I added a page and used the Plugin: Aimos Shop – Account download here. - Is that correct so far?
Another point is bread crumb path. It shows me that I am on the "Search" page when I am on the starting page of the shop. Do I have to set any uid's when I added your prepared page tree to my existing?
Kind regards
Re: Missing pages and bread crumb path
Post by aimeos » 08 Mar 2017, 10:52
You've used a very old page tree that doesn't match with the current 16.x/17.x versions.
The current version is "Aimeos-pages_two-columns_16.4.t3d" and it's available here:
https://aimeos.org/docs/TYPO3/Install_A ... etup_pages
If you want to display the product list of a pre-defined category, you have to select this category in the flexform of the "Catalog List" and "Catalog Stage" plugin.
KarstenSoll
Post by KarstenSoll » 09 Mar 2017, 15:52
OK. That pagetree works much better :lol: Thx for your quick support!
