Stripe Credit Card Information Form doesn't show up
Re: Stripe Credit Card Information Form doesn't show up
glad to here that is working now, so it was the stripe prefix, never trust the docs
what u see is the default style from stripe field (unstyled).
on stripe developer site you get some css to style the input fields.
and btw. the docs says you should use stripe.address and stripe.authorize not omnipay.adress and omnipay.authorize but i cant help u with this because im not using version 19 now.
greets tenkraD
greets tenkraD
