Order ID getting lost
cyrotek
Re: Order ID getting lost
Post by cyrotek » 03 Jul 2019, 10:44
It pops up with every payment now it seems.
How do i backtrack the error?
Post by aimeos » 03 Jul 2019, 10:48
Did you make any other changes in the checkout process?
The madmin_log table contains the stack traces and you have to check what methods are called before and why the order ID is lost (propably removed from the session somewhere).
cyrotek
Post by cyrotek » 03 Jul 2019, 11:02
How can it be lost, when it is correctly display like literally three lines underneath?
The madmin_log doesnt contain any hints regarding the missing order.id.
cyrotek
Post by cyrotek » 03 Jul 2019, 11:19
Well, it seems to be related to the rebate, whenever i add one, the error pops up, regardless of the payment method, when i dont have one added, it works.
Okay, it seems to only happen with 100% voucher, every other works fine.
It also seems that the basket isnt cleared, when i use the regular methods, the basket is empty, whenever i use the 100% voucher, it isnt.
Post by aimeos » 03 Jul 2019, 11:50
cyrotek
Post by cyrotek » 03 Jul 2019, 12:45
That worked now. Seems like the $total <= 0 was throwing the error. Thank you.
Post by aimeos » 03 Jul 2019, 13:03
We've changed the code a bit. Does it work for you too?
https://github.com/aimeos/ai-client-htm ... 9cb692610c
cyrotek
Post by cyrotek » 04 Jul 2019, 07:31
Yes, works like a charm. Thank you.
