MJML
Re: MJML
Post by aimeos » 19 Aug 2019, 08:55
Did you have a look into the Log panel in the admin interface if there are any errors logged?
cnoelker
Re: MJML
Post by cnoelker » 19 Aug 2019, 10:19
There are entries like this:
Error while trying to send payment e-mail for order ID "38" and status "5": View object not available
thrown in setView() in
Resources/Libraries/aimeos/aimeos-core/lib/mshoplib/src/MShop/Context/Item/Standard.php
Re: MJML
Post by aimeos » 19 Aug 2019, 11:05
Running the order e-mail job controllers via typo3 console won't work at the moment but you can also run single scheduler tasks by adding the appropriate CLI parameters
cnoelker
Re: MJML
Post by cnoelker » 19 Aug 2019, 11:14
Okay, this is a workaround.
Please let me know when the problem is fixed.
cnoelker
Re: MJML
Post by cnoelker » 19 Aug 2019, 11:52
The problem with this workaround: It works only once, because the job is deactivated after it was started.
And if the job is deactivated, then you can't start it again. :?
Then I would like to set the mail parameters, like this:
plugin.tx_aimeos.settings.client.html.email.from-email = somemail@mydomain.de
plugin.tx_aimeos.settings.client.html.email.reply-email = somemail@mydomain.de
plugin.tx_aimeos.settings.client.html.email.payment.from-email = somemail@mydomain.de
plugin.tx_aimeos.settings.client.html.email.payment.from-name = SomeOne
plugin.tx_aimeos.settings.client.html.email.payment.reply-email = somemail@mydomain.de
No effect at all. Did I get anything of the documentation wrong?
https://aimeos.org/docs/Configuration/C ... ail#common
Re: MJML
Post by aimeos » 19 Aug 2019, 12:01
Use
vendor/bin/typo3 scheduler:run -f -i <task id>
"plugin.tx_aimeos.settings..." is frontend only. TYPO3 doesn't have a way to set scheduler configuration for the command line. You can add the settings to the ./Resources/Private/Extensions/<extname>/config/client.php configuration file in your Aimeos extension for the project.
cnoelker
Re: MJML
Post by cnoelker » 19 Aug 2019, 13:21
Thank you, setting the from-name and other values works now.
The workaround works for me, too, because I extented my script to activate the scheduler task before it is called.
Re: MJML
Post by aimeos » 19 Aug 2019, 16:11
The view object is now part of the context and running
./vendor/bin/typo3 aimeos:jobs order/email/payment default
*should* work (depending on your settings).
Use can test using "aimeos/aimeos-typo3": "2019.07.x-dev" in your composer.json and run "composer update" afterwards.
TGergo
Re: MJML
Post by TGergo » 15 Dec 2022, 12:52
What is the directory structure where the mjml files must be copied if I want to overwrite them?
from vendor/aimeos/ai-controller-jobs/templates/[customer, order]/email/..../html.mjml
Re: MJML
Post by aimeos » 17 Dec 2022, 10:00
The same directory in your project specific Aimeos extension as in the ai-controller-jobs extension (./templates/[customer, order]/email/..../html.mjml). The MJML template isn't used directly and you have to create a PHP template with the rendered HTML code first.
